Does anyone know if the 1100 is the same as the 1200?The reason I ask is i have a gl1100 manual but i have to do head gaskets on a 84 1200 so im wondering if the torque specs and how to time it will be the same.
1200 cylinder head bolts 10mm 40 ft. lbs.
6mm 7 ft. lbs.
The UP mark on each camshaft pulley should be facing up. Align the camshaft pulley
timing mark dot (not the grooves) with the alignment mark on the heat shield.
Install the left hand belt first then the right hand belt.
Taken from the Clymer manual for 84-85 gl1200 pg. 54
