1 - 3 of 3 Posts
Do the pistons on the front calipers push in flush with a rebuild or new pads or do they stick out a bit when fully recessed ? I searched some threads but didn't see anything pertaining to this. The reason I ask is the dealer who just did the rear brake recall job showed me a picture of the pistons out about 1/4 or 3/8 inch and said pads are way low and will grind the rotor soon. they didn't remove the calipers, a week earlier I had them off to replace front tire and don't remember being concerned about the pads. The parts page shows some long piston cups. Any help is greatly appreciated.
Mike
Showing only the pistons is not the full story. You need to have a view of the pads. Replacing the pads when they have 2 mm of material left on them is a good idea. I know there is a wear limit somewhere in writing but I don't know what or where it is at the moment.
edit: I found it on page 3-17 of my 2003 Service Manual.
Reactions: Cantankerous
Check the pads you should be able the gauge the amount of lining without taking anything off and you should see a notch in the lining of it is OE this notch is the wear indicator of the lining if the lining looks thin or the notch is not visible take a 1/8 drill bit and try to insert the top that would go in the drill between the rotor and the pad backing plate If the bit doesn't fit time for pads.
1 - 3 of 3 Posts
