Honda Goldwing Forums
Honda Goldwing Forums (https://www.goldwingowners.com/forums/)
-   New Member Introductions (https://www.goldwingowners.com/forums/6-new-member-introductions/)
-   -   Im beginning to dislike HONDA (https://www.goldwingowners.com/forums/6-new-member-introductions/126997-im-beginning-dislike-honda.html)
dunlapmg 08-22-2019 04:13 PM
GREETINGS,
I'm Mike, 66 and retired. Ive got a 94 goldwing trike that has been very reliable until receintly.
Replaced the driveshaft Monday, took it for a ride and the clutch slave cylinder blew a gasket.
I noticed that in the videos I could find, most of the slave cylinders were located on the left side of
the bike, but mine is in the middle, and you can get to it from the bottom. Im not fond of jacking up
a heavy trike and crawling under it, jack stands or not.
any suggestions?
Ron Robertson 08-22-2019 06:29 PM
Never had o get to my slave cylinder. But if you have to get under the bike, you might ry running the front wheel up on a block using a ramp to get it there.
NREMTP 08-22-2019 09:08 PM
Welcome to the forum. We do have some trike experts on here and they should be along shortly to offer help.
trike lady 08-22-2019 09:23 PM
How did someone manager to put the clutch slave cylinder in a different location? They are normally mounted on the clutch cover. Now the rear brake master cylinder that can be a P.I.T.A. to find on some conversions.
Do you have a service manual for the trike? If not this may help: https://www.manualslib.com/manual/81...age=232#manual
Two Wheel Wing 08-23-2019 07:27 AM
Welcome to the GWOF from Pennsylvania.
snowmoer 08-23-2019 10:32 AM
Welcome from UT.
Honda put an extension tube with the bleeder fitting for flushing the slave cylinder of fluid in on the left side. That is what you are seeing in the videos. The slave cylinder itself on the 1500 has always been where yours is. If you remove the exhaust pipes and then the crossover chamber, this will give you more room. Jacking the rear of the bike up will just give you more room to work. I did not have to crawl under mine (non trike) when I did work in this area. I did everything on the center stand. You just have to remove some parts to get better access.
budoka 08-23-2019 10:59 AM
First off welcome, but sorry for your plight. Thanks to Dan and trike lady for the input and advice for your issue.
Since it's a trike conversion, the onus isn't really all Honda's, but also the conversion manufacturer's for making your life miserable. In Honda's defense, they didn't design Wings to have three wheels, someone else modified the machine and that's where things get kind of sideways. We love our two wheel Accords, but one of the issues for repairs and maintenance is a result of condensing a very well equipped four wheel people mover onto two wheels in as compact and tidy a fashion as possible. Add in a chassis rework and there you have it. Hope you have as little as possible trouble getting things back in order soon.
[email protected] 08-23-2019 05:15 PM
Welcome Mike: I'm a Jr Member and recently bought my first GW. The folks here are quite knowledgeable about these great bikes. Sorry to hear about your trike. Hope all works out...
ironhorse54 08-23-2019 08:28 PM
Taly Hooooooo Mon.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
