Honda Goldwing Forums
Honda Goldwing Forums (https://www.goldwingowners.com/forums/)
-   Honda Goldwing Forum General Discussion (https://www.goldwingowners.com/forums/11-honda-goldwing-forum-general-discussion/)
-   -   Where to get +12v ignition somewhere under the seat? (https://www.goldwingowners.com/forums/11-honda-goldwing-forum-general-discussion/116449-where-get-12v-ignition-somewhere-under-seat.html)
alpac 10-07-2017 06:06 PM
Hi folks,
I am planning to install a seat heater kit on my GL1800 like I did on my previous bike. It worked really well and would like to equip my G1800 with it before winter. I will use a relay to ensure that the seat heater can only be powered when the ignition is on. Before I do my own research and start testing wires with a voltmeter do you have any suggestion/idea where to get the ignition +12v somewhere under the seat?
Thanks
Techdude2000 10-07-2017 07:39 PM
Quote:
Originally Posted by alpac (Post 2027673)
Hi folks,
Thanks
If you are just looking for a trigger signal for a relay, then you could tap into the tail light wire at the 14 pin gray connector(C15). It’s the brown/white wire and only goes hot with the key on. Another option is to attach your trigger wire to the ACC terminal on the fuse box.
alpac 10-07-2017 08:18 PM
Quote:
Originally Posted by Techdude2000 (Post 2027745)
If you are just looking for a trigger signal for a relay, then you could tap into the tail light wire at the 14 pin gray connector(C15). Itís the brown/white wire and only goes hot with the key on. Another option is to attach your trigger wire to the ACC terminal on the fuse box.
Thanks :upthumbs:
liflyboy 10-09-2017 02:02 PM
For a heated seat, which will draw some amps, I would definitely go right to the fuse box Accessory terminals.
alpac 10-09-2017 06:32 PM
Quote:
Thanks but I was not asking about where to power the seat heater from but where to get the +12v ignition to trigger the relay and Techdude2000 gave me the answer. For powering the seat heater element I will go straight to the battery since the seat heater kit comes with its own fuse.
Thanks again folks.
alpac 12-28-2017 02:44 PM
3 Attachment(s)
Yesterday I finally installed a seat heater kit similar to this one https://www.ebay.com/itm/Universal-M...FUnDgh&vxp=mtr
Today I tested it in 29℉ and it worked really good. Here are pics of the two switches front and rear and a pic of the front heating element being installed under the front seat cover.
budoka 12-29-2017 08:39 AM
Looks like a job well done Alain!
alpac 12-29-2017 02:44 PM
Quote:
Thanks. I tried to make it not look too much like an aftermarket add-on. Bottom line cost is around $70 and about 3h of work.
Powered by vBulletin® Version 3.8.8
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
