Help - Honda Goldwing Forums
 1Likes
  • 1 Post By JK McDonald
post #1 of 8 (permalink) Old 05-21-2019, 05:46 PM Thread Starter
Junior Member
joetazzz's Avatar
Question Help
hey I am new to owing a Goldwing I have a 1985 Honda Goldwing GL1200 Interstate
and I am having a problem with my turn signals are not working . trying to find the turn signal relays .but no luck I did find the 4 way flasher relay but I can not find the turn signal flasher relay
joetazzz is online now
post #2 of 8 (permalink) Old 05-21-2019, 11:38 PM
Lifetime Premium
Ron Robertson's Avatar
Welcome to the GWOF.
Sorry I can't help you.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #3 of 8 (permalink) Old 05-22-2019, 04:32 AM
fossil92's Avatar
Garage
Welcome to the GWOF.....We have some very talented 1200 mechanical people here. Be patient and I'm sure one of them will be along to help.
GWOF IB COUPLE #2
FR #91
fossil92 is online now
post #4 of 8 (permalink) Old 05-22-2019, 04:40 AM
superdave1120's Avatar
Welcome from the northern tier of PA. As Bill said some smart 1200 people will be along with the answers to your questions. Enjoy the forum and ride safe.
Superdave1120
Sayre, PA
1980 650 Yamaha First Ride
1989 GL1500 First Wing
2006 750 Shadow Wifes Ride
2012 GL1800 New Wing (Red)
IBA #63784
Darksider #1664
Michelin Alpine P3 195/55/R16
superdave1120 is online now
post #5 of 8 (permalink) Old 05-22-2019, 06:23 AM
Two Wheel Wing's Avatar
Welcome to the GWOF from the Keystone state. Someone on the forum will have your answer.
Charlie
Proud Owner of IDMWT #1
Past rides:
1974 Blue Yamaha TX500
1986 Red Kawasaki Voyager 1200
1998 Illusion Red Goldwing 1500 SE
2009 Silver Goldwing 1800 Audio/Comfort
***(all dropped, all gone, but none forgotten)***
Present:
2003 Electron Blue Metallic Corvette 5.7
Faith is more than believing God can, it's knowing God will.
Elected officials like diapers need to be changed regularly, both for the same reason. Mark Twain
Two Wheel Wing is online now
post #6 of 8 (permalink) Old 05-22-2019, 08:21 AM
budoka's Avatar
Garage
Good morning and welcome. While I'm no 1200 expert, being as your bike is an '85 model, the turn signal relay should be located under the steering stem near the signal control unit and the position relay. However, there are a multitude of tests on various connectors in the harness that may also require testing for continuity/current flow. Do you have a shop manual? If not, PM me and I'll see about getting you some pdf's of the appropriate sections/pages.
Of course one of our members that is a tad more familiar and current with the 1200 could still jump in and confirm or deny what I have found so far.
Daryl
budoka is offline
post #7 of 8 (permalink) Old 05-22-2019, 08:10 PM
JK McDonald's Avatar
Turn Signal - 4 Way Flasher Relays -
Hey Joe - Like the 1500 GW - the 1200 turn signal and 4 way flashers are actually divided into two (almost) identical circuits and except for the Auto-Canx Control Unit - troubleshooting is pretty straight forward.
There are 2 interchangeable Flasher Relays. 1 operates the Turn Signals and 1 for the 4 way flashers. The two relays are mounted across from each other near the yoke below the ignition unit. The false tank must be removed for access.
1 Have the turn signals ever worked properly ? Are the bulbs the original filament style - or have you replaced them with the newer LED's.
2 Do both Left and Right (Front/Rear) turn signal lights come on - just don't flash ?
3 Do the 4 way flashers work ?
4 From memory (?) I think there are two fuses to check - fuse 5 (15 amp) = turn signal relay power, and an (In-Line) fuse below the fairing pocket insert = 4 way flasher relay power.
5 The handle bar - Turn Signal Switch internal contacts can be the source of the problem. Carefully disassemble the switch contacts and clean. Watch for the small parts to try and escape.
6 Inspect both flasher relay socket connections and/or relay pins for corrosion. Swap the two flasher relays - Retest the Turn Signals.
If you have to chase down a wiring or ground problem you'll need a schematic for some color codes and additional component locations.
Keep Us Posted - Michael
Name:	sam_7138_e1be4c1482263658 - Copy (2).jpg
budoka likes this.
JK McDonald is offline
post #8 of 8 (permalink) Old 05-24-2019, 01:04 PM
Turn Signals -
Hey Joe - Are you still having to use hand signals to indicate a turn while riding ?
Michael
Linear Mode Linear Mode
