Removing the final drive side flange on a 2005 GL - Page 2 - Honda Goldwing Forums
 3Likes
post #11 of 15 (permalink) Old 08-12-2019, 01:42 PM Thread Starter
Junior Member
yellow05's Avatar
Quote:
Originally Posted by ETC View Post
I have had these apart and yes remove the screws and wack it with a lead hammer - don't spray wd-40 on it as that just makes a mess. The ring should pop off once you jar it loose.
Normally when the seal leaks one of the paired bearings is bad causing the ring gear assembly to wiggle. Better check that as you may wish to simply replace the entire unit instead. get a hold of a rear trike conversion outfit and just pay them the $50 bucks for a replacement would be my choice.
Thanks for that but I wonder if were talking about the same part. The part I need to remove is a flat flange that goes over the wheel studs. The parts manual has it as FLANGE, FINAL GEAR SIDE 41441-MCA-010.
I've done everything I can think of to get some movement out of it, including the hammer, without breaking other things in the process, and it just wont budge.
I've looked on ebay for drives and ones under 100k miles are around $200 with shipping. Fair price? If not, where should I look?
Thanks for the help,
Denny
Keep on Tourin'
The Wanderer
yellow05 is offline
post #12 of 15 (permalink) Old 08-12-2019, 03:36 PM Thread Starter
Junior Member
yellow05's Avatar
I found a 2010 final drive with 40k miles on ebay for $119 shipped, so I bought it.
If I ever get the flange off I'll post what it took.
Thanks, everyone, for the help.
The Wanderer
Luv2fish likes this.
Keep on Tourin'
The Wanderer
yellow05 is offline
post #13 of 15 (permalink) Old 08-15-2019, 04:09 PM Thread Starter
Junior Member
yellow05's Avatar
Someone on another board suggested longer bolts thru the rotor mounting holes might jimmy it off, and that worked. There are a lot of tight fit diameters, dowels and studs that keep it in place and all that stuff just makes it difficult to get off.
Unfortunately, what I found underneath is ugly. It appears the bearing suffered a failure - don't know why, maybe just age because I serviced it more often than the maintenance schedule. The bearing cage started to disintegrate and several balls are missing and apparently somewhere inside the case. This debris then tore up the seal. It would take a total tear down, and probably every rotating part, including the gears, would need replaced.
So I just receive the used drive and it appears to be in good shape.
If anyone has any tips to installing one of these, I'm all ears.
Thanks again,
Denny
Name:	GL final drive5 small.jpg
ID:	264841   Click image for larger version
Name:	GL final drive8 small.jpg
ID:	264843   Click image for larger version
Name:	GL final drive3 small.jpg
Chopin likes this.
Keep on Tourin'
The Wanderer
yellow05 is offline
post #14 of 15 (permalink) Old 08-15-2019, 04:12 PM
ETC
ETC's Avatar
Garage
yep that is what they do when they go bad one of the bearing retainers breaks which trashes the bearing or bearings as there is a pair. And this has nothing to do with oil or service it is most likely a defect. It is quite rare as I have only seen one so far but every unit that has failed seems to have the same large bearing fail.
"Take the Right Turn"
ETC is online now
post #15 of 15 (permalink) Old 08-16-2019, 10:34 AM
budoka's Avatar
Garage
And the learning process continues. Something for many of us to pay attention to
Daryl
budoka is offline
Linear Mode Linear Mode
