LED Lights on my Trailer = Problems? - Honda Goldwing Forums
 1Likes
  • 1 Post By Ron Robertson
post #1 of 9 (permalink) Old 04-15-2019, 05:51 PM Thread Starter
Member
Hello from Wisconsin. I have a 1999 standard Aspencade 1500. It came with a 5 pin trailer hookup. My trailer (from another bike) had a 4 pin.
I am changing the trailer wiring to 5 pin and also plan to change the lights to all LED.
My question is this: Do I have to do anything before I hook up the standard light bike to an LED light trailer?
Thanks.
JJ
99 Aspencade
79 LTD CB750K x2
80-81 CB750F x4
81 CB900F
83 Suzuki GS850L
jj2bucks is offline
post #2 of 9 (permalink) Old 04-15-2019, 06:09 PM
Member
Darkside#1500's Avatar
It depends but most likely there are no changes to the bike. Whether your trailer plug is getting power directly from the bike's harness or you have an isolation relay setup, so long as the current directionals work correctly, the addition of the LED trailer lights should work correctly.
You all set with the five wire hookup on the trailer (ground, running lights, all brake lights, left directional, right directional)?
Andy Cote
Darkside #1500
2015 Goldwing, black
previously: GL1200 Standard, GL1200 Interstate GL1500 Wing, GL1500 Valkyrie Standard, 2000 Valkyrie Interstate and many other Hondas
Darkside#1500 is offline
post #3 of 9 (permalink) Old 04-15-2019, 06:12 PM
dsurley's Avatar
Garage
my only other question, that may throw you a curve ball.
If your trailer has only a 4 pin connector, to me that means that the brake and turn lights run on the same bulb. on the wing that is not the case, they are on different bulbs.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #4 of 9 (permalink) Old 04-15-2019, 06:15 PM Thread Starter
Member
Yes. That is exactly how the set up is for the lights.
99 Aspencade
79 LTD CB750K x2
80-81 CB750F x4
81 CB900F
83 Suzuki GS850L
jj2bucks is offline
post #5 of 9 (permalink) Old 04-15-2019, 06:18 PM Thread Starter
Member
Dsurley, I have changed the wiring (or will soon) of the trailer to 5 pin to match the wing.
99 Aspencade
79 LTD CB750K x2
80-81 CB750F x4
81 CB900F
83 Suzuki GS850L
jj2bucks is offline
post #6 of 9 (permalink) Old 04-15-2019, 06:20 PM
dsurley's Avatar
Garage
to get lights to work correctly.
you will need to add a pair of lights on the trailer and wire them in.
with out seeing your set up to be sure, just going by typical wiring for trailers
on the four pin connector, the brown wire should be tail lights
the yellow and green - one is left turn and the other is right turn
(they were energized together for brake light)
white wire would be ground
Since the wing runs turn and brake lights off of different bulbs, you will have to do the same on the trailer, as in add a pair of lights to act as brake lights.
This being said........ there is some sort of adapter that is made for such things..... but not cheap
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #7 of 9 (permalink) Old 04-15-2019, 06:23 PM
dsurley's Avatar
Garage
http://wingstuff.com/products/38048-...?from_search=1
this is the part in question
not as much as I thought
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #8 of 9 (permalink) Old 04-15-2019, 06:37 PM
Lifetime Premium
Ron Robertson's Avatar
Go to your local Auto parts store, they may have a conversion plug. to match the two systems.
dsurley likes this.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #9 of 9 (permalink) Old 04-15-2019, 07:40 PM Thread Starter
Member
Oh my gosh. I looked and looked for that part. I went to dealers and parts stores. Jeepers.
99 Aspencade
79 LTD CB750K x2
80-81 CB750F x4
81 CB900F
83 Suzuki GS850L
jj2bucks is offline
Linear Mode Linear Mode
