2006 GOLDWING Key will not turn the engine off - Honda Goldwing Forums
 6Likes
  • 3 Post By Jinx
  • 3 Post By Techdude2000
post #1 of 4 (permalink) Old 08-06-2018, 12:02 AM Thread Starter
Junior Member
My 2006 Goldwing 1800 starts okay but when I turn the key to off nothing happens. I have to use the kill switch to stop the engine but the dash lights remain on. To turn everything off I have to pull the 10 amp fuse marked "HEAD MAIN" in the main fuse box. To start the trike the fuse must be replaced and the whole scenario starts again ?????? I sure hope someone has the solution to this old guy's problem.
Ridengeezer
RIDENGEEZER is offline
post #2 of 4 (permalink) Old 08-06-2018, 03:59 AM
Jinx's Avatar
Bad ignition switch. Check to see if when you turn the key the switch itself also turns. If so check to see if there is a short in the wires
LOCK SET part # 35010-MCA-A61
SWITCH ASSY., COMBINATION & LOCK part # 35100-MCA-A62
BASE, CONTACT part # 35101-MCA-A62
fossil92, budoka and 13wing like this.
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
post #3 of 4 (permalink) Old 08-06-2018, 04:19 PM
NREMTP's Avatar
Garage
Welcome to the forum. Let us know how the switch checks out.
Bob
2012 ABS "Red Ghost"
IDMWT 65
NREMTP is online now
post #4 of 4 (permalink) Old 08-06-2018, 10:09 PM
Member
Quote:
Ridengeezer
One quick question. Do you have the high beams on? If so, turn them off and see if the bike shuts down with the key. If it does, you have a ground issue in the fairing harness behind the gauge assembly. If it still doesnít turn off with the key, then itís definitely your ignition switch.
budoka, Chopin and Jinx like this.
Candy Red 2004
Techdude2000 is offline
Linear Mode Linear Mode
