2018 GW Tour DCT Tire Change Time - Honda Goldwing Forums
 2Likes
  • 1 Post By dsurley
  • 1 Post By W1ngin1t
post #1 of 4 (permalink) Old 04-16-2019, 11:33 PM Thread Starter
Member
Vegas's Avatar
Garage
Well I have just a little over 9,000 miles on the 2018 and I'm down to barely 3/32" of tread left. I figure these stock tires are only good for about 10,000 miles. So now I'm starting my search for tires. There are only 2 tires every site is showing for the new wing. A set of Dunlop D423 Honda Goldwing Tires, and a set of Bridgestone G853-G Exedra Honda Goldwing Tires. The 2018+ wing has a rear 200/55/R16 and front 130/70/R18. The front tire I can get in just about any brand I want, but that huge rear tire is only made for the new wing. So I've also been weighing my option to go to the Dark Side. I tend to be aggressive when in the twisties, so my main concern is what type of Car Tire I should go with. I have been on www.darkside.nwff.info and saw that the most common size CT is a 195/55/16 for the rear. I then started listing the brands and models of tires used to see which were used the most. The following tires are what I figured were more common dark sided.
Continental ContiPro Contact 40K mile tire (replaced by)
Continental Pure Contact LS 70K mile tire.
Kumho Ecsta PA31 50K mile tire.
Bridgestone Drive Guard RF 60K mile tire.
Bridgestone Potenza Pole Position RE960AS 65K mile tire.
My question is, those of you that have the 2018+ Goldwing, what are you thinking of going with as a replacement rear tire?
For those of you that have been Dark Siding for more than 2 sets of tires, I'm curious as to what you all suggest.
Vegas is online now
post #2 of 4 (permalink) Old 04-17-2019, 01:56 AM
W1ngin1t's Avatar
i Have run dark side on my Ď08 and had no issues 20+k out of each of them...ran three tires and I ran the Hankook Ventus V4 non runflat.
As far as the DCT Wing I have been curious as to what size to run because there is no 200/55/16 car tire that I could find and would be worried the DCTís computer would throw a code or not shift right for running an improper tire size.
Let us know how you make out please.
Mark
2018 Goldwing Tour DCT Candy Ardent Red
'07 Trekker DL185 Trailer
AMA Member
DSi # 563 IDMWT #14
Riding soothes my soul.....
W1ngin1t is online now
post #3 of 4 (permalink) Old 04-17-2019, 05:42 PM
dsurley's Avatar
Garage
First I do not have a 2018
But I would check into a 205/50/16 as the replacement
205 makes it only a total of 5mm wider....so 2.5mm to each side..... so that should be close enough
and 205 x .50 = 102.5 sidewall height
the oem tire 200 x .55 = 110 sidewall ( I know the shape of the tire will affect this to an extent)
It would be closer in size than the 195 we all run on the earlier wings, the earlier used a narrower back tire
budoka likes this.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #4 of 4 (permalink) Old 04-25-2019, 10:34 AM
W1ngin1t's Avatar
Be aware if you're putting a hitch on, the 205 will rub.
Go with the 195.
mikew568 likes this.
Mark
AMA Member
DSi # 563 IDMWT #14
Linear Mode Linear Mode
