removal of 1500 wheel - Page 2 - Honda Goldwing Forums
 2Likes
post #11 of 17 (permalink) Old 07-21-2019, 05:53 PM
Junior Member
Swivelhip's Avatar
Garage
Doesn't anyone remove the seat then the bolt thru your bags, flip the bags and trunk up out of the way, loosen both mufflers, swing them down and pull the axle?
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!”
Swivelhip is online now
post #12 of 17 (permalink) Old 07-22-2019, 06:49 AM
Member
Darkside#1500's Avatar
Quote:
My preferred method. Not everyone agrees but just seemed to me to be less impact and once the rear frame section is pivoted up, you have clear room to do everything you want.
Andy Cote
Darkside #1500
2015 Goldwing, black
previously: GL1200 Standard, GL1200 Interstate GL1500 Wing, GL1500 Valkyrie Standard, 2000 Valkyrie Interstate and many other Hondas
Darkside#1500 is offline
post #13 of 17 (permalink) Old 07-22-2019, 09:13 AM Thread Starter
Junior Member
Just finished with the rear tire, brakes and shaft and splines
Sent from my SM-G970U using Tapatalk
golwang97.tang is online now
post #14 of 17 (permalink) Old 07-22-2019, 10:57 AM
Lifetime Premium
Ron Robertson's Avatar
Which bolts through the saddle bags ???, are you talking about the ones inside the bags ????
Looks like the rear crash bars have to come off in the picture.
I'd like to try this some time.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #15 of 17 (permalink) Old 07-22-2019, 10:40 PM
Junior Member
Swivelhip's Avatar
Garage
There is one bolt inside each bag. I will try to include the picture pointing to this bolt one time when I had to remove just one bag. Also included is a picture of the bolt you remove, after several times of this mine got roughed up a bit.
Name:	IMG_4438 - Copy.jpg
ID:	264389   Click image for larger version
ID:	264391   Click image for larger version
post #16 of 17 (permalink) Old 07-23-2019, 06:01 AM
Member
There are access holes thru the forward end of the saddlebag to reach those bolts. I changed bolts as well but went with socket head to be easier to reach and install. BTW these lower bolts do not have to be completely removed though you may want to, especially the first time. The rear subframe has open forks that go over these bolts. When mine was open, I smoothed the forks up and filed a bevel on the opening to help things go back together.
The top bolts under the seat need to be loose of course. Don't forget to retighten them.
The two halves of the inner fender are plastic and have interlocking tabs. They will unsnap on the way up but might need some help to line up correctly on the way back down.
And golwang97 you really threw me off with that picture. Took a couple looks to figure out that it was fringe on your surrey.
Andy Cote
Darkside #1500
post #17 of 17 (permalink) Old 07-23-2019, 03:09 PM
budoka's Avatar
Garage
I don't miss those days, and the days of my 1200 tire replacement. Used to remove all the necessary stuff before taking it in to have the tire(s) changed. Not that I do my own on the 1800 but still, those 5 hub bolts are a great improvement IMO
Daryl
budoka is offline
Linear Mode Linear Mode
