Where is the leak? - Honda Goldwing Forums
 28Likes
post #1 of 18 (permalink) Old 02-15-2019, 01:14 PM Thread Starter
EFINREF's Avatar
Where is the leak?
Hey boys,
I'm just glad I have a mechanical question for you all to figure out. So here goes:
I don't always check my air pressure before I ride. However, my school decided to take today off and the weather is decent, so I of course wanted to take a short ride. I haven't ridden in near 10 days, so I thought I should check the pressure. Normal air loss over time is usually 5 to 7 lbs. The front tire showed 34 and then........the back tire showed 12. I took it off the center stand and yep, it was very low (so my gauge is accurate).
Here is the confusing part:
I aired the tire up and soak it with soapy water....Nothing!!! The stem, side walls.....Nothing!!!
SO!!!! Where is the leak?
2008 ST 1300
IDMWT#2
IBA #49803
SS1000 and BB1500
THE VERY FIRST GWOF IB w/RALPHUMOR
No longer on the Darkside -
"It eases my mind to know, that in times like these, there have always been times like these."
Paul Harvey
EFINREF is online now
post #2 of 18 (permalink) Old 02-15-2019, 01:25 PM
Lifetime Premium
Chopin's Avatar
You have a trough bucket ? If not, steal one from farmer Jones next door or one of Darleen's plastic plant troughs. You need to slowly rotate that rear tire in a bath tub.
EFINREF likes this.
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #3 of 18 (permalink) Old 02-15-2019, 01:57 PM
Cantankerous's Avatar
Garage
It's from the valve core, one of the balance beads has it stuck open.
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Cantankerous is offline
post #4 of 18 (permalink) Old 02-15-2019, 03:36 PM
Jinx's Avatar
When was the last time you checked tire pressure ? If it was recently I would agree with the bead theory if longer I would look at the tire bead area. But as
much as I hate to admit it Chopin have the best solution for finding the leak.
Had a car tire that had a slow leak that I could never find. Did everything including cleaning bead area , remounting the tire, soaping it good and letting it
seat nothing. But about once a month it would need to be pumped up. Finally fixed the problem by selling the car.
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
post #5 of 18 (permalink) Old 02-15-2019, 04:09 PM
Lifetime Premium
Ron Robertson's Avatar
If you have beads in the tire, when you check the pressure be sure the stem in on the bottom and to tap the valve stem with a wrench before you put the air gauge on, to knock any beads out of the stem.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #6 of 18 (permalink) Old 02-15-2019, 05:22 PM
Lifetime Premium
Chopin's Avatar
Quote:
Originally Posted by Jinx View Post
But as
much as I hate to admit it Chopin have the best solution for finding the solution.
Could you repost that ? I didn't have my hearing aids in.
Lee.
post #7 of 18 (permalink) Old 02-15-2019, 06:33 PM
dsurley's Avatar
Garage
On rare occasions.......... during the tire construction...... the inside of the tire doesn't get a good seal job.... and it will slowly seep through the tire itself.......... some tire brands are more prone that others. Have had a car tire with this problem..... lost about 10psi per week.
But as others have said..... could just be the valve core.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Double Darkside Bridgestone BT45 Battlax Front
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #8 of 18 (permalink) Old 02-15-2019, 06:41 PM
Jinx's Avatar
BUT AS MUCH AS I HATE TO ADMIT IT CHOPIN HAS THE BEST SOLUTION FOR FINDING THE LEAK.
Does that work ?
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
post #9 of 18 (permalink) Old 02-15-2019, 07:20 PM
crownfire's Avatar
I find the change in temperatures from cold to hot and back to cold again we get this time of year messes with the tire pressures. Hope you figure out your problem.
Jinx likes this.
Mark
It matters not how good you are if an angel pees on the flintlock of your musket. Old German Military saying.
2010 Honda GL1800
GWOF IB Hat #1 with WARWGN
IDMWT #86
crownfire is online now
post #10 of 18 (permalink) Old 02-15-2019, 08:05 PM
Lifetime Premium
Chopin's Avatar
Does that work ?
I hear you now. You dont have to SHOUT !
W1ngin1t and jcsouders5464 like this.
Lee.
Linear Mode Linear Mode
