Where is the leak? - Page 2 - Honda Goldwing Forums
 28Likes
post #11 of 18 (permalink) Old 02-16-2019, 03:17 AM
W1ngin1t's Avatar
https://memes.yarn.co/yarn-clip/8f35...yGmzBIHSE.copy
fossil92, crownfire and EFINREF like this.
Mark
2018 Goldwing Tour DCT Candy Ardent Red
'07 Trekker DL185 Trailer
AMA Member
DSi # 563 IDMWT #14
Riding soothes my soul.....
W1ngin1t is online now
post #12 of 18 (permalink) Old 02-16-2019, 10:42 AM Thread Starter
EFINREF's Avatar
Checked the pressure this morning and it had dropped from 35 to 32. Gonna have to keep a check on this rascal until I have it changed.
2008 ST 1300
IDMWT#2
IBA #49803
SS1000 and BB1500
THE VERY FIRST GWOF IB w/RALPHUMOR
No longer on the Darkside -
"It eases my mind to know, that in times like these, there have always been times like these."
Paul Harvey
EFINREF is online now
post #13 of 18 (permalink) Old 02-16-2019, 12:44 PM
Lifetime Premium
Chopin's Avatar
Did you do the bucket bath yet ?
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #14 of 18 (permalink) Old 02-17-2019, 06:59 AM Thread Starter
EFINREF's Avatar
No!!!
"Darleen" doesn't have a planter trough and can't find anything I could use without taking my wheel off. I ain't gonna take that wheel off......I have the replacement tire ready, I just wanted to wait till closer to the MnG.
2008 ST 1300
IDMWT#2
IBA #49803
SS1000 and BB1500
Paul Harvey
post #15 of 18 (permalink) Old 02-17-2019, 07:40 AM
Lifetime Premium
Chopin's Avatar
I admire your resolve for an easier resolution .
crownfire likes this.
Lee.
post #16 of 18 (permalink) Old 02-17-2019, 09:20 AM
Garage
Quote:
Originally Posted by EFINREF View Post
No!!!
Then do it the lazy way. Get a spray bottle put some dish soap and warm water in it. Lay on the ground and spray it all over. You will see little tiny bubble. It might take 15 minutes but it will bubble up. The dish soap will coat the tire and a small leak will produce very small bubbles. Spray it and walk away. When you come back you will see a streak of little bubbles. Worst case you now have a clean tire and wheel. Yes check the wheel. The air can leak thru the metal. And pump it up more. Try 50 to 60 lbs if you don't find it at 41.
Don't get lazy on us a ride on a bad tire. You might not make it thru to the other side when it decides to become a big leak.
Luv2fish likes this.
Behind "Goldwing" Bars
I'm Claustrophobic so I ride a motorcycle
Behind bars is online now
post #17 of 18 (permalink) Old 02-18-2019, 09:13 AM Thread Starter
EFINREF's Avatar
Words to live by. I tried the soapy water and it is losing about 2 lbs per day. I will pump it higher and try that. I won't get lazy, I'll just replace it.
Behind bars likes this.
2008 ST 1300
IDMWT#2
IBA #49803
SS1000 and BB1500
Paul Harvey
post #18 of 18 (permalink) Old 02-20-2019, 11:48 AM
Junior Member
Wingrider7's Avatar
I don’t remember reading on here whether anybody mentioned the actual valve stem and whether it has been changed or not because the rubber will deteriorate over time and as a rule you should change the valve stem every two tire changes if you’re using the stock valve stems. Are use the heavier duty steel ones which will last a lot longer. Even then I usually change those out after the third tire. I had the same issue with my rear tire and it turned out to be the valves stem. At first I thought it was the core, but changing that had no effect. I always carry a spare valve stem cores, But I will be adding the actual valve stem to my little parts box in the saddlebag.
Chopin, crownfire and Behind bars like this.
Wingrider7 is offline
Linear Mode Linear Mode
