99 1500 Goldwing coolant leak - Honda Goldwing Forums
 12Likes
post #1 of 16 (permalink) Old 03-13-2019, 09:36 PM Thread Starter
Junior Member
My 99 1500 Goldwing has a coolant leak. (Sweet smelling mist) When I had the front tire replaced last fall at the Honda shop, the mechanic thought it was the intake manifold gaskets leaking, but didn't get into it enough to be sure. Taking it back tomorrow for a further teardown to determine where the leak is coming from. If it is the intake manifold gaskets, possibly over $1,200 to replace. As an alternative, wondering what type of antifreeze stop leak to try? Someone recommended antifreeze stop leak aluminium! Didn't know if motorcycle aluminium engine requires special stop leak fluid! Looking for recommendations if that's the route I take.
kennyk is offline
post #2 of 16 (permalink) Old 03-14-2019, 05:26 AM
fossil92's Avatar
Garage
Welcome to the GWOF from PA.
As a mechanical person and someone who does their own maintenance, I would not use a stop leak unless absolutely necessary. Sometimes it's a very simple thing, like either a radiator cap, or the coolant reservoir.
Not telling you that you are wrong to do so, but just offering an opinion. If it is an intake manifold, it will be a lot of teardown which is why it will be costly, but if you are mechanical it is not a hard task.
ETC likes this.
GWOF IB COUPLE #2
FR #91
fossil92 is online now
post #3 of 16 (permalink) Old 03-14-2019, 05:40 AM
flash's Avatar
It might be a good idea to have a pressure test first before taking it apart. It seems to me if it is the intake manifold, the bike would steam out of the exhaust. It might be as simple as a hose clamp that needs tightening.
fossil92, NREMTP and Luv2fish like this.
flash is offline
post #4 of 16 (permalink) Old 03-14-2019, 08:33 AM
Lifetime Premium
Ron Robertson's Avatar
The clamps on the the large radiator hose have been know to need tightening after the bike ages. The hose will weep a bit.
Honda used to put a clear tape on the hose connection that would dry and crack with age that caused a weep on those connections, On my 93 I removed the hose and cleaned the tape off.
budoka likes this.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #5 of 16 (permalink) Old 03-14-2019, 09:02 AM
budoka's Avatar
Garage
There are also sometimes burrs on teh fittings that weep as they age. A simple bit of sanding down will fix that. Once you locate the problem of course.
Daryl
budoka is offline
post #6 of 16 (permalink) Old 03-14-2019, 10:41 AM
JK McDonald's Avatar
Emergency -
Hey Kenny - I agree with the other members in recommending that you not try "stop leak" to solve the coolant loss. Your problem could very easily be only a loose clamp or hose down under the front cowling somewhere. There are lots of carburetor heating and engine cooling connections to check.
A "stop leak' product is most often used as a temporary solution in an emergency attempt to get you home. Although - As a kid I routinely added a can of STP and Radiator Stop Leak to my old "Beat-Um-Up Work Truck" that used almost as much water and oil as gas.
Ride Safe - Michael
JK McDonald is offline
post #7 of 16 (permalink) Old 03-14-2019, 11:30 AM Thread Starter
Junior Member
Thanks for your replies. I"ll see what the mechanic finds. I live in Alaska, and don't have a place to work on the bike myself, (still too cold and wet to work outside), and, I am not very mechanically inclined. I can do the simple maintenance, (changing air filters, etc.,) but if it's the intake manifold gaskets, a little more than I could probably do. Will advise once I find out.
kennyk is offline
post #8 of 16 (permalink) Old 03-14-2019, 01:50 PM
Lifetime Premium
Another little trick I found works. When the wing is stored in a COLD location, I put one of those old Mechanic trouble lights with a 60 watts bulb in it under the engine and leave it turned on 24/7 tall winter long. It doesn't keep the engine toasty warm but it helps reduce the effect on the cold on the engine. My old 93 would drip during the winter then i heard about the light under the engine, no more drips. I now do that on my 99.
Ron
IDMWT #5
post #9 of 16 (permalink) Old 03-14-2019, 04:10 PM
Member
Alan_Hepburn's Avatar
Garage
I've always wondered how the stop-leak products can tell the difference between a tiny water passage that is supposed to be there and one that isn't supposed to be there?
Alan Hepburn
1994 GL1500SE with a California Friendship I Sidecar
Alan_Hepburn is online now
post #10 of 16 (permalink) Old 03-14-2019, 05:49 PM Thread Starter
Junior Member
Update: The Honda mechanic found moisture around the water pump. He says he could not check the weep hole because it's' facing against a metal shield, and he won't be able to see it until he actually takes it out. He said he couldn't see any other place it was leaking. He also said there were small metal flakes in the antifreeze, which, along with the moisture, is the reason he wants to replace the water pump.
He also said the antifreeze in the bike was green. The Honda antifreeze is blue. The last radiator flush was done at the same shop, but a different person who is no longer working there. The current mechanic asked if I had put automotive antifreeze in it, but I assured him I did not, as I bought 2 extra Honda approved quarts from them.
A new water pump has been ordered. Will take about a week to get here. I will update once it's installed!
kennyk is offline
Linear Mode Linear Mode
