no neutral light, no start, 2010 1800 - Honda Goldwing Forums
 14Likes
post #1 of 33 (permalink) Old 06-30-2018, 06:23 PM Thread Starter
Keefer269's Avatar
worked fine yesterday, today, no worky. I tried the obvious easy stuff, shifted back an forth multiple times, operated side stand multiple times, flicked start button and on/off switch and ignition multiple times, said a few bad words multiple times, Everything else seems to be working fine, all the lights work. Without taking the bike all apart, what shall I check next. 2010 1800
EDIT: I should also have said that it wont crank.
2010 GL1800AC 'Have road, will travel'
Texas hill country + fine rides + single + early retirement = one happy guy
Keefer269 is offline
post #2 of 33 (permalink) Old 06-30-2018, 07:14 PM
dsurley's Avatar
Garage
It should still start with the side stand up and clutch lever in....... just like if you stall it at a light.
Maybe if you actually move it around under power and shift gears.... then the neutral light will clear and work... crazy things do happen.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Double Darkside Bridgestone BT45 Battlax Front
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #3 of 33 (permalink) Old 06-30-2018, 08:46 PM Thread Starter
Keefer269's Avatar
no, it won't, I did rock it some to switch gears
post #4 of 33 (permalink) Old 06-30-2018, 09:40 PM
dsurley's Avatar
Garage
crazy question....... didn't on accident engage the reverse button
W1ngin1t likes this.
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #5 of 33 (permalink) Old 06-30-2018, 10:15 PM Thread Starter
Keefer269's Avatar
tried that...... battery is only couple months old
post #6 of 33 (permalink) Old 06-30-2018, 10:31 PM
dsurley's Avatar
Garage
trying to go thru all the stupid stuff I and friends have done.
question, does everything else power up like it is supposed to and do the head lights go out when you hit the start button?
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #7 of 33 (permalink) Old 07-01-2018, 01:55 AM Thread Starter
Keefer269's Avatar
yep, everything else works, yes lights go out,
but this time I noticed the PGM-FI malfunction indicator lamp comes on. Didn't notice it earlier today. It comes on for about 1.5 seconds then off, no other blinks. Did a search and found this. http://www.syncshop.nl/VTEC/DiagnosecodesVTEC.pdf
Right at the top for no blinks, engine doesn't start.......where are these relays mentioned? am I gonna have to take it to the dealer ? ouchy $$$$$$
post #8 of 33 (permalink) Old 07-01-2018, 11:45 AM
dsurley's Avatar
Garage
I am sure someone on here has a honda service manual for your bike.... I have one, but it is for the 2012-up 2nd Gen 1800 and I know lots of stuff got moved so I know it won't help you.
May have to post another thread asking who has a service manual for your year Wing.
Some also have said they had trouble with the "bank angle sensor" which also kills the engine.
But I would try to follow up on the codes.
"wrote this before reading the link,,,,,, and one of the no blink codes is the bank angle sensor"
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #9 of 33 (permalink) Old 07-01-2018, 11:55 AM
dsurley's Avatar
Garage
Did a search on GL1800 Riders forum for the bank angle sensor and found an article
http://gl1800riders.com/forums/5-gl1...?action=thread
not saying this is your problem..... just trying to toss out some ideas and help you find stuff.
IDMWT member #80
non-runflat
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #10 of 33 (permalink) Old 07-01-2018, 01:13 PM
flash's Avatar
Just for the hell of it, did you try disconnecting the battery let it sit for a few minutes and then try to start. Might be nothing but never know.
flash is online now
Linear Mode Linear Mode
