no neutral light, no start, 2010 1800 - Page 3 - Honda Goldwing Forums
 14Likes
post #21 of 33 (permalink) Old 07-02-2018, 11:35 PM
Member
From the service manual
If the neutral indicator does not light with the key on and transmission in neutral then pull the combination meter and check the black/white wire for battery voltage with the key on. This will be the number 2 pin with black/white wire. Test that pin to ground with volt meter.
If you don't have voltage there it all points to the reverse system. Or connectors.
Faulty reverse position switch
Faulty reverse shift switch.
Open circuit in the black/white and the black/red wires between the combination meter and reverse shift switch.
Open circuit in the black/brown wire between the reverse shift switch and reverse position switch.
Loose our poor contact of related connectors
If you do have voltage there, then:
Turn ignition switch to off.
Check continuity between the light green/red wire of the combination meter gray connector and ground.
Continuity yes:. Replace the meter assembly
Continuity no:. Faulty gear position sensor
Or open circuit in the light green/ red wire between the combination meter and the gear position sensor.
Or loose our poor contact in related connectors.
Sent from my XT1254 using Tapatalk
guyval is offline
post #22 of 33 (permalink) Old 07-02-2018, 11:40 PM Thread Starter
Keefer269's Avatar
Quote:
Originally Posted by guyval View Post
Does it go into reverse?
No
I suspect one of the switches in that assembly.
Contact cleaner or WD40? lol
NREMTP likes this.
Keefer269 is offline
post #23 of 33 (permalink) Old 07-03-2018, 12:06 AM
Member
Quote:
Originally Posted by Keefer269 View Post
No
Now it's making more sense.
The reverse system / switching is looking more like the culprit.
Maybe just a good cleaning of the switches could do it.
It'd be nice if that's it.
My luck would be much deeper.
Contact cleaner is a good start.
I'd be interested to learn what becomes of this since mine is the same year
Guy
guyval is offline
post #24 of 33 (permalink) Old 07-03-2018, 12:51 AM
Cantankerous's Avatar
Garage
how much did that assembly cost you? Did you replace it yourself, if so, how hard was it?
The switch assembly, if I remember correctly, was ~$180.00. I did do the work myself, see the pictures as to how involved it was. (For me anyway.)
ID:	256609   Click image for larger version
Keefer269 likes this.
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Last edited by Cantankerous; 07-03-2018 at 12:53 AM. Reason: Pictures didn't load.
Cantankerous is offline
post #25 of 33 (permalink) Old 07-03-2018, 07:09 AM
Lifetime Premium
Chopin's Avatar
No
WD-40 for sure!
Lee.
A Darksider since I finally saw the Light.
Chopin is online now
post #26 of 33 (permalink) Old 07-03-2018, 10:55 PM Thread Starter
Keefer269's Avatar
took the assembly apart, sprayed it down real good with contact cleaner, then douched it with some wd-40, put it back together and after operating all the switches a few dozen times, success! Neutral light comes on, bike starts, go for a ride, cruise control won't set, so I'll have to work on that button some more, but most likely will end up having that assembly replaced. Cheaper to do it now rather than get stranded somewhere. Since they have to take the top half of bike off to change wiring harness, may as well change air filter while they are there.
Chopin and dsurley like this.
2010 GL1800AC 'Have road, will travel'
Texas hill country + fine rides + single + early retirement = one happy guy
post #27 of 33 (permalink) Old 07-03-2018, 11:16 PM
Member
I'm glad you got it going, that's great!
If you get in there ( the switch assembly) again, put some dielectric grease in there.
On all the moving parts.
Most Auto parts stores sell it.
A little dab will do. Use a tooth pick or something like that.
Spray the contacts with cleaner and operate them if you can while spraying and flooding it clean.
Good luck
Guy
fossil92 and Keefer269 like this.
guyval is offline
post #28 of 33 (permalink) Old 07-04-2018, 12:39 PM
dsurley's Avatar
Garage
I "Try" to remember to work all of the switches and buttons several times at least once a month.
My previous Wing I was the 3rd owner...... never could get some switches to work..... but they weren't ones that I never really needed to use.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Double Darkside Bridgestone BT45 Battlax Front
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #29 of 33 (permalink) Old 07-05-2018, 02:32 AM
TmDILL's Avatar
I blow air into my switches periodically. Set the compressor at about 15psi and blow the dust out. I've never had a problem.
Terry Dill of San Antonio
It's not the destination, but the getting there.
TmDILL is online now
post #30 of 33 (permalink) Old 07-05-2018, 09:36 PM
Member
Sounds like the reverse shift switch was dirty. It connects the power for the neutral light to the gauge assembly and the reverse relay. Without this power getting through the switch, it won’t crank the engine no matter whether it’s in gear or in neutral. It also would not have connected the power to the reverse control module to activate reverse.
Chopin and Keefer269 like this.
Candy Red 2004
Techdude2000 is offline
Linear Mode Linear Mode
