Problem is back! - Page 2 - Honda Goldwing Forums
 17Likes
post #11 of 18 (permalink) Old 05-07-2018, 11:24 AM
edmKC's Avatar
Quote:
Originally Posted by Dog Breath View Post
Yes there was a fix at this point. Techdude2000 from GL1800 forums (who is know as the GL1800 DR) said that the wiring and C25 connector could be the blame. He said it’s common that the C25 connector over time causes problems. Because the wing was constantly stalling and had 1 over heating issues because the fans didn’t kick on, made him believe it was an electrical problem. After examining, cleaning, disconnecting/reconnecting the C25 connector, checking for loose wires and the entire harness, I must have triggered something. I let it idle for 1 hr and took 2 20 mile trips with it and had zero problems and the fans kicked on when they needed too. I recently took a trip that was over 7 hours, over 350 miles with my fiancé, in 85 degree weather, with stop and go traffic, and the wing had no problems. So at this point it is fixed. It surely would have shown it’s ugly face after all that. Techdude said if it comes back that the problem is obvious, it’s the sensor loop down the engine or the C25 connector will need to be “re-done”. So to answer your question she is up and running, whether I fixed it permanently or by “accident”.
Glad you're up and rolling again.
What/where is the 'C25 connector'?
Dog Breath likes this.
2006 Honda GL1800
2012 Ural Patrol
Previous bikes:
2010 Kawasaki Vulcan 900 Classic
1983 Suzuki GS850G
1982 Yamaha Vision 550
edmKC is online now
post #12 of 18 (permalink) Old 05-07-2018, 08:08 PM Thread Starter
Member
Dog Breath's Avatar
Garage
Under the seat, near the relay box. Mine was wrapped up in electrical tape along with the rest of the wiring harness. If you just feel around for it, you will find it.
2006 Honda Goldwing ABS
2014 Honda CRF250L
2015 Honda CTX 700 DCT ABS
2017 Honda CB300F ABS
2017 Yamaha FJ-09
2018 Honda Grom
2017 Yamaha FZ-09- sold
2014 Honda CTX700 -sold
Dog Breath is offline
post #13 of 18 (permalink) Old 05-08-2018, 11:27 AM
edmKC's Avatar
Thanks for that.
2006 Honda GL1800
2012 Ural Patrol
Previous bikes:
1983 Suzuki GS850G
edmKC is online now
post #14 of 18 (permalink) Old 05-09-2018, 04:58 PM
budoka's Avatar
Garage
One thing I really don't like about all this new technology bundled into tight places is the possibility that wires can get pinched or cracked and where do you start in the gremlin search? A shorted circuit can cause ridiculous problems if it goes sideways. The picture is when I replaced the air filter on my '09, and in the process, I discovered a bolt end had worn through the protective rubber coating on the wire harness. Lord knows what that would have shorted out in the middle of nowhere....
Daryl
budoka is offline
post #15 of 18 (permalink) Old 05-09-2018, 05:31 PM
Lifetime Premium
Ron Robertson's Avatar
Ok; I haven't seen this for myself, but one of my 1800 riding buddy, I think it's an 2004 was telling us about the wires feeding the lights in his trunk lid braking because of the way they are attached, flecking every time you open and close the lid. He recommended taking them out of the clip on the lid. Like I said I haven't seen it myself..
Badrider and Dog Breath like this.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #16 of 18 (permalink) Old 05-09-2018, 09:42 PM
Lifetime Premium
Badrider's Avatar
Quote:
I had that shortly after I bought my 09. The remote key chain fob wouldn't work, and it ended up being a broken wire where the wires flex on the trunk lid.
Every man dies, not EVERY man truly LIVES!
Steve
GWRRA
1980 CB750 * 1979 GL1000 * 1982 GL1100 *
2000 GL1500 * 2009 GL1800 Airbag
IDMWT #99 (Finally admitted because I like the sound of #99)
Badrider is offline
post #17 of 18 (permalink) Old 05-22-2018, 10:36 PM
Member
There’s no trunk light wires in the hinge harnesses except for the spoiler light brake light circuit, but the trunk lock control unit has its wires running through the right side hinge area and it shares the ground circuit with all of the rear lights on the bike. A common failure point for the rear ground circuits is a bad connection that develops in the gray 14 pin connector under the seat, near the trunk. The solid green wire will get loose in the connector and start generating heat until it melts the connector and completely disconnects itself and possibly damage the connector to affect other wires running through it. The fix for it is to solder a permanent jumper across the connector on the green wire, bypassing the bad connection. Be aware there are two large gray connectors under there, one has only 12 wires and it’s not the problem child, the 14 wire one is the connector of interest. This is a common failure of the 01-08 year models. Towing a trailer without an isolator in the lighting circuits will accelerate the failure.
Candy Red 2004
Techdude2000 is offline
post #18 of 18 (permalink) Old 05-22-2018, 11:32 PM
jcsouders5464's Avatar
Garage
AS an Automotive Master tech I keep telling people I just fixed it by accident
jcsouders5464 is online now
Linear Mode Linear Mode
