Slow charging 2018 Goldwing DCT Tour - Honda Goldwing Forums
 1Likes
post #1 of 8 (permalink) Old 10-26-2019, 09:34 PM Thread Starter
Junior Member
Hi,
Need to figure out a way to wire up a port to hook up my slow charger without having to remove the seat every time. Anyone have any suggestions?
Thanks
Bob Sears is online now
post #2 of 8 (permalink) Old 10-26-2019, 11:18 PM
Junior Member
rglanvil@msn.com's Avatar
Amazon has some cables for about $5 each. See attached picture.
Name:	Tetra-Tenica Cable.jpg
Chopin likes this.
post #3 of 8 (permalink) Old 10-26-2019, 11:44 PM
Junior Member
Install a Powerlet socket,
azccj is online now
post #4 of 8 (permalink) Old 10-28-2019, 10:01 AM
budoka's Avatar
Garage
If you are referring to the main battery, the Optimate III comes with a pigtail that can be left accessible for plugging the charging unit into. I keep mine tucked in behind the left side cover, but you can leave it exposed for easy access.
Daryl
budoka is offline
post #5 of 8 (permalink) Old 10-29-2019, 07:56 AM
Junior Member
I have a pigtail coming out the side cover for my heated gear. I then have an SAE to Coax adapter
with which I plug in my battery maintainer.
https://www.warmnsafe.com/collection...battery-tender
2018 White Gold Wing Tour DCT
2016 Suzuki DL650A
Ray N. is online now
post #6 of 8 (permalink) Old 10-29-2019, 05:25 PM
Member
Garage
Not sure why you are removing the seat at all. Last year on my 2018 Tour DCT I pulled the left side cover off then connected the Battery Tender slow charger with medium size alligator clips to the battery. The left side cover has no bolts just plastic posts that snap into grommets. To get it off you have to open the left saddle bag then pull on the side cover to release it from the grommets. Cruiseman has some videos on YouTube that show how to remove and install the right side panel but the left one is the same. I simply stored the panel beneath the motorcycle during this storage period.
This year I won't have to remove the panel since the Honda accessory plug was installed by me in the panel that houses the parking brake. That accessory plug was installed to give me access to the battery for running an air compressor or charging my iPhone or Cardo Packtalk while parked. Connecting a Battery Tender through it is just another convenient thing it can do.
DesertRat is offline
post #7 of 8 (permalink) Old Yesterday, 10:45 AM
Junior Member
Garage
what model of charger are you using? and is it the official Honda accessory socket you have installed? Would like to do something similar on my bike but already have an Optimate charger.
Dave J is online now
post #8 of 8 (permalink) Old Yesterday, 09:31 PM
TmDILL's Avatar
You can buy the same extensions that come with the Battery Tender. They bolt straight to the battery and you can put the other end sticking out of the side cover hole or under the seat near the passenger grab handle. I bought a second cable and ran it from the same spot as my battery tender cable and under the seat and inside the trunk where I used the loose end to wire in a second ACC plug to charge my cell phone while riding. When I ride on long trips I plug the battery side tender cable to the cable to the trunk. When I use the battery tender, I unplug those two and plug the tender into the battery side cable. I never have to take off the side cover or the seat. But note: If you leave the battery tender cable connected to the trunk cable, the ACC plug is always live but fused. Which can be a good thing if you need to charge an IPOD while stopping to eat or something.
I have been using a Battery Tender for over 10 years and my current battery is 4 years old. I like the fact that it is not really a charger but a maintainer and when the green light is on the battery is good. If it is red it is charging which is always after I park or do something to the bike where I turn the key on and off. A Battery Tender will not charge a dead battery.
I also have a Lithium Jumper Battery with a cable attached. When I'm riding and have disconnected the Tender, I connect it to the Jumper Battery. I can do it while sitting on the bike before backing out of the garage.
I don't like to use the slow charger function of a bigger battery charger because they can over charge a battery. This is especially noticeable on lead acid battery that you have to add water. They will boil the water out and then the battery is toast.
Terry Dill of San Antonio
It's not the destination, but the getting there.
TmDILL is online now
Linear Mode Linear Mode
