CB unit on GL2001 be used in GL2008 - Honda Goldwing Forums
post #1 of 6 (permalink) Old 10-14-2019, 03:12 PM Thread Starter
Junior Member
I purchased a 2008 GL1800. Can the CB unit and antenna unit from the 2001 be installed in the 2008 model? or does it require a lot of setup?
The question is can the CB unit that installed in a 2001 GL1800 be used in the 2008 GL1800?
Last edited by gdickins1225; 10-14-2019 at 04:46 PM. Reason: Rephrase the question
gdickins1225 is offline
post #2 of 6 (permalink) Old 10-14-2019, 03:18 PM
Member
Yes it can I have both but I didn't install it. it came installed when i purchased the bike.
Sent from my LM-G710 using Tapatalk
phillipgym is online now
post #3 of 6 (permalink) Old 10-15-2019, 12:52 PM
joe in calif's Avatar
Garage
The unit is the same bit the place where the main wire harness connects is in a different location . If I remember correctly. the early 1800 wing CB connection was on the left side under the top shelter, the 06 and up the main connection was on the right side and you got to it by removing the key panel that opens the right storage compartment on the fairing. This is where it is on the 06 wing
joe in calif is online now
post #4 of 6 (permalink) Old 10-15-2019, 05:30 PM Thread Starter
Junior Member
In the early wings 2001 the CB connector is in the trunk.
post #5 of 6 (permalink) Old 10-17-2019, 10:41 AM
Garage
The main connector is not in the trunk. The place where you put the CB is in the trunk, you have to drill a hole in the trunk to snake the wire thru, one of the connector is under the seat
Look at this
http://goldwing.eurekaboy.com/cb.htm
post #6 of 6 (permalink) Old 10-17-2019, 11:01 PM
TmDILL's Avatar
Quote:
Look at this
Joe, you are correct. There is a spot on the right lower side inside the trunk that is marked for that hole which is about 1" in diameter. It is an impressive molded marking. Also the main connection is under the seat beside the cross bar just rear of the Box with all the Relays. Also the Antenna for the CB has marks right where the holes are drilled for it. Also where the antenna cable routes through the trunk. In addition on my 2005 one filter is plugged into the harness just to the right along side the engine of the ignition so that top shelter has to be removed to find it.
Terry Dill of San Antonio
It's not the destination, but the getting there.
TmDILL is online now
Linear Mode Linear Mode
