Key won’t go in all the way - Honda Goldwing Forums
 20Likes
post #1 of 21 (permalink) Old 09-09-2019, 07:15 PM Thread Starter
Junior Member
Hi all, so I used a tube of granite powder on my locks today and when I went to put my goldwing key in the ignition of my 01 Wing, the key went in just over half way into the ignition slot. I’m not sure what happened but I stuck the tube or graphite into the ignition hole spritzed a little. Now the key won’t go in and I’m thinking I got too much graphite or a piece of the plastic tip in there. Anyone have any thoughts as I don’t wanna screw up my screw up any more. I have tried blowing air into the key cylinder hole. I can’t really see too well into the hole to see if there is an obstruction. I’m not sure how to go about it.
Thanks for your input guys.
slammerman is online now
post #2 of 21 (permalink) Old 09-09-2019, 07:21 PM
Jinx's Avatar
I'm not sure about the 01 but on the 06 it was possible to remove and dis-mantle the ignition switch. If I remember right there is just two screws holding it in.
If you do take it apart keep track of the order of the pins.
NREMTP likes this.
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
post #3 of 21 (permalink) Old 09-09-2019, 07:23 PM
NREMTP's Avatar
Garage
You mention granite powder and then graphite powder???
I suggest using a vacuum cleaner. If that does not work you may have to take the ignition switch out, invert it and try to get whatever you put in it out. If that does not work, then you will probably have to disassemble the switch.
Bob
2012 ABS "Red Ghost"
IDMWT 65
NREMTP is online now
post #4 of 21 (permalink) Old 09-09-2019, 09:19 PM Thread Starter
Junior Member
Yes I mean to say graphite powder. Thanks for your suggestions.
post #5 of 21 (permalink) Old 09-10-2019, 05:42 AM
Two Wheel Wing's Avatar
If there is something stuck a good strong shopvac over the lock should work.
Charlie
Proud Owner of IDMWT #1
Past rides:
1974 Blue Yamaha TX500
1986 Red Kawasaki Voyager 1200
1998 Candy Spectra Red Goldwing 1500 SE
2009 Silver Goldwing 1800 Audio/Comfort
***(all dropped, all gone, but none forgotten)***
Present:
2003 Electron Blue Metallic Corvette 5.7
Faith is more than believing God can, it's knowing God will.
Elected officials like diapers need to be changed regularly, both for the same reason. Mark Twain
Two Wheel Wing is online now
post #6 of 21 (permalink) Old 09-10-2019, 05:57 AM
Lifetime Premium
Chopin's Avatar
Quote:
Powder ? That will do it. Next time we " grease " the key. Maybe a spray of WD-40 will liquefy the powder. Put some of that powder on a surface and hit it with WD-40 and see what it does.
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #7 of 21 (permalink) Old 09-10-2019, 06:58 AM
crownfire's Avatar
You have already read the suggestions I would make. Hope the flushing or vacuum works.
Mark
It matters not how good you are if an angel pees on the flintlock of your musket. Old German Military saying.
2010 Honda GL1800
GWOF IB Hat #1 with WARWGN
IDMWT #86
crownfire is online now
post #8 of 21 (permalink) Old 09-10-2019, 07:20 AM
Junior Member
Hi all, so I used a tube of granite powder on my locks today and when I went to put my goldwing key in the ignition of my 01 Wing, the key went in just over half way into the ignition slot. Iím not sure what happened but I stuck the tube or graphite into the ignition hole spritzed a little. Now the key wonít go in and Iím thinking I got too much graphite or a piece of the plastic tip in there. Anyone have any thoughts as I donít wanna screw up my screw up any more. I have tried blowing air into the key cylinder hole. I canít really see too well into the hole to see if there is an obstruction. Iím not sure how to go about it.
O M G !!!
Why in the world did you put graphite in key hole?
Only people who use graphite nowadays is the U.S. Navy. BUT they strip and clean the locks on a regular basis.
WD-40 or Silicone Spray works great. (And you don't have to wipe your key off before putting it back in your pocket.)
You might try flushing it out with WD-40. Spray profusely again and again until key goes in and out easily.
Keep a rag handy as the graphite makes a huge mess.
TnT Tom is online now
post #9 of 21 (permalink) Old 09-10-2019, 08:55 AM
budoka's Avatar
Garage
I'd remove the ignition barrel and clean it off the bike. Worse comes to worse if it's pooched, it has to come out anyway...
Jinx and NREMTP like this.
Daryl
budoka is online now
post #10 of 21 (permalink) Old 09-10-2019, 08:39 PM
dsurley's Avatar
Garage
Quote:
Originally Posted by TnT Tom View Post
O M G !!!
graphite being dry....doesn't attract dust, dirt, and pocket lint like liquid grease does.... and does not get stiff in the freezing temps..... locks that I use graphite powder in stay working much longer than any lock that I have used WD40 or Liquid Wrench.... I have used the last two if a lock has been hanging outside for years and hasn't been taken care of just to get it to open.... then use carb cleaner to get all the grease out and graphite it.
You just can't over do it or like he said... can't get the key in.... you should try it.
Jinx likes this.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Double Darkside Bridgestone BT45 Battlax Front
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
Linear Mode Linear Mode
