Turn signals self cancel - Honda Goldwing Forums
 5Likes
  • 2 Post By budoka
  • 2 Post By dan18960
  • 1 Post By Jinx
post #1 of 10 (permalink) Old 08-22-2019, 08:07 AM Thread Starter
Jinx's Avatar
My turn signal are not cancelling when I turn them on and then turn the handlebars from lock to lock. My understanding is that the angle sensor on the triple tree sends a signal, ground , to cancel the turn signal when the handlebars are returned to center. The turn signal self cancel after I have traveled a set distance so that is working fine and they cancel when I press the turn signal switch. So that part is working.
I have gone thru the troubleshooting section upto the point where I have to remove the shell to get to the diode . Also I have checked the clip that connects the angle sensor to the frame so it is not that.
So I am asking if I am right that the turn signal should cancel when the handlebars are turned from lock to center ?
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
post #2 of 10 (permalink) Old 08-22-2019, 02:42 PM
budoka's Avatar
Garage
Jinx, I believe there is a motion sensor in the system so if you are sitting still turning the bars lock to lock will not cancel the signal lights. But as often happens, I could be mistaken on this....
Jinx and NREMTP like this.
Daryl
budoka is offline
post #3 of 10 (permalink) Old 08-22-2019, 03:18 PM
Member
The turn signals do not work as your 4 wheel vehicle does. They are on a distance sensor. They will cancel automatically for making turns and when passing.
captain78 and dsurley like this.
Proud Owner of IDMWT #102
2004 Black GL1800A Gold Wing
1997 Black/Silver Kawasaki Vulcan 750
dan18960 is online now
post #4 of 10 (permalink) Old 08-22-2019, 04:58 PM Thread Starter
Jinx's Avatar
Quote:
I think you are right. There may have been a bad connection in the system. I went for a ride today and the turn signals were working as expected. Right after straightening up from a slow speed turn the turn signal would turn off. Before they would not turn off until I had traveled some distance.
Thank you for your reply.
NREMTP likes this.
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
post #5 of 10 (permalink) Old 08-22-2019, 05:03 PM Thread Starter
Jinx's Avatar
Quote:
They cancel with speed and the angle sensor. I believe that turns from a stop both the angle sensor and speed sensors come into play.
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
post #6 of 10 (permalink) Old 08-23-2019, 06:24 AM
Member
Quote:
I have never had my turn signals cancel from making any turns. If I "tap" the turn signal button at a traffic stop and I make the turn it still flashes for the same distance as when I use them for passing. And I have scraped the pegs on many a left/right turn that would definitely activate any angle sensor IF that disabled them.
So when I tap them at a traffic stop - I manually cancel them after I make the turn (but if I forget - they cancel themselves in less than a quarter mile).
post #7 of 10 (permalink) Old 08-23-2019, 06:59 AM Thread Starter
Jinx's Avatar
The angle sensor is in the steering head. It senses when the forks are turned, in a slow speed turn, and then returned to center.
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
post #8 of 10 (permalink) Old 08-23-2019, 12:33 PM
Lifetime Premium
Chopin's Avatar
You can test whether the angle sensor is working or not by dropping the bike on either the left or right side.
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #9 of 10 (permalink) Old 08-23-2019, 03:47 PM
ironhorse54's Avatar
Ha ha Ha ha ha, very true. I know mine is working perfectly.
Eddie
2018 DCT Tour Pearl Hawkeye Blue
IDMWT #73
"Ride hard or stay home"
ironhorse54 is online now
post #10 of 10 (permalink) Old 08-23-2019, 04:41 PM Thread Starter
Jinx's Avatar
Different sensor and I know that one works.
Went out to the bike and put in on the center stand. Started the engine and put it in second gear, speed about 20mph. Turned the left signal on and waited for it to turn off . Turned off after about 10 sec. Pulled in the clutch and brake as if I was stopped at an intersection. Turned on the left turn signal and let out the clutch as if pulling out from the intersection, turned the handlebars left then back to center. Right after the handlebars were returned to center the turn signal turned off.
So I am sure the turn signals are working .
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
Linear Mode Linear Mode
