Nitrogen vs Air in Tires - Page 3 - Honda Goldwing Forums
 63Likes
post #21 of 26 (permalink) Old 08-21-2019, 08:26 PM
Member
captain78's Avatar
If your dealer is doing it free of charge then go for it. If the dealer wants to charge you for the nitrogen, tell him to pound sand. There is no real advantage for street use to warrant an extra cost.
823Jim and DesertRat like this.
2006 Navi- Triked in 2013
captain78 is online now
post #22 of 26 (permalink) Old 08-22-2019, 07:56 AM
TmDILL's Avatar
Quote:
Originally Posted by Chopin View Post
Running Nitrogen is fine, but if you need a top off some day will you have access to Nitrogen where and when you need it ?
I totally agree. Nitrogen does hold the tire pressure because it is not as acceptable to temperature changes. Ask NASCAR. But, if you develop a leak, then what.
Terry Dill of San Antonio
It's not the destination, but the getting there.
TmDILL is online now
post #23 of 26 (permalink) Old 08-22-2019, 08:05 AM
TmDILL's Avatar
Funny claim about running Nitrogen and getting better tire wear. Nitrogen inside the tire holds better pressure has nothing to do with the rubber wearing out on the outside of the tire. Friction is Friction. The only advantage is the close to constant air pressure in the tire. And those of us to constantly check that pressure will always have good tire wear because we don't let the tire get 10 pounds too low or high.
DesertRat likes this.
post #24 of 26 (permalink) Old 08-22-2019, 09:08 AM
Member
Garage
My two cents worth. Higher pressure air holds less water vapor than lower pressure air. When an air compressor compresses the air to a higher pressure the water vapor turns to liquid and falls out. That is why it is very important to drain your air tank regularly with its accumulated liquid water which will eventually corrode the inside of your tank. Another thing, pressure is a condition of a material and not a property. Whether it is pure nitrogen, air (Nittorgen/Oxygen mix), helium, or whatever 40 psi is 40 psi. Regarding temperature sensitivity, specific heat of a gas is a property which would change the operating temperature of the tire some. Without dragging out my thermodynamics book to look up the specific heat of gases I would suspect there is very little difference since air is 79% nitrogen.
DesertRat is offline
post #25 of 26 (permalink) Old 08-22-2019, 01:10 PM
Terryj's Avatar
Garage
I run 78% nitrogen in my tires, it's called air.
captain78 and SeaDogActual like this.
9th ID, US Army
Vietnam 69-70
Disabled Veterans of America
Member of MOPH (Military Order of the Purple Heart)
Terryj is online now
post #26 of 26 (permalink) Old 08-26-2019, 06:24 AM
tamathumper's Avatar
Garage
I only run air, but I make sure to ask for metric air.
After a few months of topping up the tires as the pressure drops, I find I'm running 98% metric nitrogen because all the smaller molecules are the ones that leak out, leaving behind the big fat nitrogen ones.
Terryj, 823Jim and DesertRat like this.
'03 GL1800A | Porsche 968 | Ford F-150 | Skidoo GSX (2) | Seadoo GTI (2) | Suzuki ATV (2)
A.A.O.N.M.S. | NRA Endowment | Gun Owners of America | Oath Keepers | IDMWT #97
tamathumper is online now
post #27 of 26 (permalink) Old 08-26-2019, 05:19 PM
Lifetime Premium
Chopin's Avatar
This forum is filled with N ₂O.
NREMTP likes this.
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #28 of 26 (permalink) Old 08-26-2019, 05:30 PM
NREMTP's Avatar
Garage
But that is easily and frequently displaced by CH4.
Bob
2012 ABS "Red Ghost"
IDMWT 65
NREMTP is online now
Linear Mode Linear Mode
