Electrical help for a friend - Honda Goldwing Forums
 1Likes
  • 1 Post By Cantankerous
post #1 of 4 (permalink) Old Yesterday, 04:34 PM Thread Starter
Wayfarer's Avatar
I have a friend who owns a 2003 Goldwing trike. The tripometer and clock are resetting frequently. His radio occasionally stops and restarts but does not lose station memory.
One time yesterday it suddenly died but started back with no problem.
My thoughts were loose battery plug but he checked and said they are good. I also though possible loose plugs on panel behind dog house. However I donít know why that would have made it die.
Any thoughts?
Just a way faring stranger
IDMWT#85
Wayfarer is online now
post #2 of 4 (permalink) Old Yesterday, 10:06 PM
Cantankerous's Avatar
Garage
Check this thread: https://www.goldwingowners.com/forum...-resets-1.html
It might help.
Wayfarer likes this.
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Cantankerous is offline
post #3 of 4 (permalink) Old Today, 04:05 PM Thread Starter
Wayfarer's Avatar
Thanks Cantankerous. We will give it a look
IDMWT#85
post #4 of 4 (permalink) Old Today, 09:08 PM
JK McDonald's Avatar
Voltmeter -
Hey Wayfarer - Intermittent electrical issues are a real pain to sort out. You can have an ignition switch, poor fuse socket, wiring harness connection or a failing alternator.
To help troubleshoot this type of problem - you should install a dash mounted Volt Meter to monitor the charging system. A failing alternator can cause the 1800 computer to unpredictably shut down if it's input/supplied voltage falls below (approximately) 10 volts. The reason is because the fuel injection/ignition calculations for the engine are no longer accurate.
If the Voltmeter stays up around 14 volts when the bike shuts down - you're next step will likely be to look for a wiring issue.
Good Luck and Keep Us Posted on Your Progress - Michael
JK McDonald is online now
