Broken Tupperware - Page 2 - Honda Goldwing Forums
 13Likes
post #11 of 19 (permalink) Old 07-02-2019, 05:17 AM
Member
pidjones's Avatar
ABS cement is no longer readily available at Home Depot, Lowe's, Ace etc. here in East Tennessee. ABS plumbing doesn't meet code here, I think. But, good ole' Amazon is shipping a can to my door today. I'll be using it to repair a tab on my '78 GL1000. The repairs can be reinforced with fiberglass cloth if needed. I used it with wrecked GL1800 plastic to build a entire new under-cowl piece for the '79 CB750F that I rescued over the winter.
pidjones is online now
post #12 of 19 (permalink) Old 07-02-2019, 11:38 AM
jcsouders5464's Avatar
Garage
Quote:
Originally Posted by Luv2fish View Post
This holds the side cover on. It is the one connected to the saddlebag. Iíd like to fix it although I donít believe the bike will fall apart if I donít. Any thoughts on how it might be fixed?
Too much pulling them off when connecting the straps to hold the bike in the trailer.
Steve
Plastex. From Amazon or Eastern. Eastern gives you a range of colors. I was able to repair the trunk lid hinge mounts. and with a little added steel wire, I was able to make it I was even able to make it stronger than designed which could possibly help you. Make your mold from the front side and strengthen the backside.
IDMWT Member #96
J.C.
1975 Honda GL1000 Mule deer really liked it
1982 Honda CM450E 118K when finally fell apart
2007 Yamaha V-MAX Rejetted Carbs made it scary fast.
2014 Goldwing Basic in black
Ride everyday except when raining (or snowing) on the way to work.
jcsouders5464 is online now
post #13 of 19 (permalink) Old 07-02-2019, 11:44 AM
Garage
And I do not recommend any petroleum based lubricant on rubber. I use silicone lubricant. Small tube goes a long ways. Oil based causes the rubber to swell as most rubber grommets are made from oil.
As evidenced when an ounce or less of oil in brake fluid will make all rubber parts in the brake system swell, causing permanent damage. Same as other rubber components. You can see this in the rubber cell phone covers from Otterbox. Over time the oils from your hands cause the cover to swell.
AND before any one shoots me down. Rubber engine seals are not rubber but a viton or silicone rubber.
Chopin likes this.
IDMWT Member #96
J.C.
post #14 of 19 (permalink) Old 07-02-2019, 04:30 PM
Junior Member
Keith Wilder's Avatar
Once upon a time I too thought the petroleum damage to rubber was permeant. You can actually resuscitate the rubber by boiling it. Apparently this causes the rubber to release the contaminants. I found that hack on youtube and have used it a couple times with 100% success.
Keith Wilder is online now
post #15 of 19 (permalink) Old 07-03-2019, 11:13 AM
Junior Member
Take a look at this product. Its a cyanoacrylate compound that works well for bonding and rebuilding ABS, PVC among other plastics. www.plast-aid.com.
I've found that silicone spray or grease works well on grommets.
drzzzzz is offline
post #16 of 19 (permalink) Old 07-03-2019, 08:40 PM
Junior Member
I saw a utube video, I believe by cruzman, where he used a plastic repair kit. He said it seemed to work pretty well. You might look for that utube and see if it is something you might want to try.
Wayne
NVWayne is online now
post #17 of 19 (permalink) Old 07-04-2019, 12:33 AM
Garage
Quote:
Wayne
That was the Plastex, I mentioned.
IDMWT Member #96
J.C.
post #18 of 19 (permalink) Old 07-04-2019, 05:29 AM Thread Starter
Luv2fish's Avatar
I just ordered the Plastex. I'll let you know how it works.
Steve
2015 Goldwing NAV/ABS
IDMWT #81
Fredericksburg, Virginia
Luv2fish is online now
post #19 of 19 (permalink) Old 07-04-2019, 11:09 AM
Junior Member
Great, keep us posted. Iím sure many broken tabs will be in need of repair at some point in the future.
Wayne
Linear Mode Linear Mode
