My turn signals are driving me nuts. HELP!!! - Honda Goldwing Forums
 1Likes
  • 1 Post By Ron Robertson
post #1 of 10 (permalink) Old 06-22-2019, 01:29 PM Thread Starter
slowrollin's Avatar
About a month ago, my turn signals stopped working on my 2015 Wing. I was riding and when I hit the signals, nothing seemed to happen. Took the bike to the shop and it spent the next three weeks there all taken apart with the Mechanic and Honda on the phone trying to figure out what was wrong. Finally came down to replacing the turn signal cancellation switch and a relay, which was replaced with some kind of "LED Relay".
Rode the bike about 250 miles or so with no issue after that. Put it away for a week, then went out for a ride today and the signals stopped working again.
Went back to the shop (another 37 miles) and they didn't work the whole time, until the last turn I made to go into the shop parking lot. They continued to work while they were checking me in, and then started working on and off.
We noticed that if you tapped on the fairing just below and forward of the mirrors where the fairing kind of raps around the forks, the signals would begin to work. Tap there again and they would stop. After awhile of trying to figure that out, the signals just stopped blinking again.
My lighting set up is the following. I have the Electrical Connections LED bulbs in the high and low beams. I have LED turn signals in the rear and led tail lights. I have the Add-On Fog Lights, which look just like the SoCal daytime running light, foglight, turn signal combo.
I need the bike in a week for a trip up to Canada, so I'm getting pretty nervous. Any ideas would be really appreciated!!!
slowrollin is online now
post #2 of 10 (permalink) Old 06-22-2019, 01:57 PM
Lifetime Premium
Ron Robertson's Avatar
A few years ago I bout some LED bulbs for the rear tail light for my 93 1500 they work ok sometimes than wouldn'r . Put the old standard bulbs bac in and no more problems.
W1ngin1t likes this.
From the Northwest Corner
Ron
The Land of Tall mountains
IDMWT #5
Ron Robertson is online now
post #3 of 10 (permalink) Old 06-22-2019, 03:12 PM
Jinx's Avatar
slowrollin where are you located ? PM me if you don't want your location public.
Form what you are describing I would check the the turn signal relay or the cancel switch/wiring in the triple tree. The cancel switch is in the bottom and the wiring comes out the top.
My bet is the relay connector is loose.
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
post #4 of 10 (permalink) Old 06-22-2019, 05:25 PM Thread Starter
slowrollin's Avatar
No problem on the location Jinx. I'm in South Jersey. I'll ask the mechanic to check the relay connector. They said they put in a new relay and new cancel switch. Since it was working intermittently for awhile today, it does kind of sound like something is loose rather than blown. Especially since it responded when we would tap on the fairing.
post #5 of 10 (permalink) Old 06-22-2019, 05:31 PM
Jinx's Avatar
I'm in Harrisburg,Pa. My garage is always open . You are not that far away.
2017 Red Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
George Bernard Shaw
Jinx is online now
post #6 of 10 (permalink) Old 06-22-2019, 05:33 PM Thread Starter
slowrollin's Avatar
Thank you Jinx! Really kind of you and I greatly appreciate it. I'll definitely keep that in mind!!!
post #7 of 10 (permalink) Old 06-22-2019, 07:11 PM
Member
I sure hoped you paid the service department as it is not a manufacturer defect but an issue with the items you installed or the installation of the items. LED bulbs do not have the same electrical draw as the filament bulbs that the signal switch and relay were designed for. I would check the connections from the LED foglights to the turn signals behind the mirrors making sure they are snug and snapped together. I would also run a zip tie to keep the connectors from pulling apart. I would also get a high quality LED turn signal flasher too that others have had good luck with. Pathfinder sells them if needed.
Joflewbyu2 is online now
post #8 of 10 (permalink) Old 06-23-2019, 09:44 AM Thread Starter
slowrollin's Avatar
Quote:
I don't think I ever had any thoughts that it's a manufacturers defect. Even it it was, the bike is no longer under warranty, so I'm paying for the repairs. When the LED flashers were installed in the rear of the bike, I believe a unit was installed to ensure they flashed in sync, and it was from Pathfinder. My understanding was if that wasn't installed they flashers wouldn't work properly. However, my problem seems to be coming from up front somewhere.
post #9 of 10 (permalink) Old 06-23-2019, 10:52 AM
Lifetime Premium
Chopin's Avatar
I bought a LED flasher relay from Electrical Connection.com. It went south. Pulled it out and it was just an exposed circuit board. No wonder when it rained I had my first issue. The flasher is located in front of the dash and can be accessed by removing the dash cover and getting your fingers down there.
Lee.
Darksider since I finally saw the Light.
Chopin is online now
post #10 of 10 (permalink) Old 06-23-2019, 05:08 PM
Member
The flasher relay is located up front below the dash. Did they install LED resistors that are suppose to be connected to the metal frame as they need to shed off heat.
https://tstindustries.com/blog/tech-...-vs-resistors/
Linear Mode Linear Mode
