Electrical question - Honda Goldwing Forums
 3Likes
post #1 of 26 (permalink) Old 03-09-2019, 03:58 PM Thread Starter
Member
Kilt Guy's Avatar
Electrical question
I was looking at an 86 wing today. The guy just put in a new battery and as he fired it up this connector got hot and melted. This sits next to the left side of the battery and the lower portion goes into the engine. It starts right up but it doe's not take long for these wires to start to get warm. What would cause this and how do I fix. I know I need to replace the wires.
Kilt Guy is online now
post #2 of 26 (permalink) Old 03-09-2019, 04:37 PM
Cantankerous's Avatar
Garage
That's the stator connector, they are well known to go bad. If you remove the connector and solder the wires it might still charge, but it possibly has a bad stator.
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Cantankerous is offline
post #3 of 26 (permalink) Old 03-09-2019, 04:45 PM Thread Starter
Member
Kilt Guy's Avatar
That is what I thought it was. How hard is it to change out the stator? Can I unplug it and run the bike to get it home?
post #4 of 26 (permalink) Old 03-09-2019, 06:14 PM
bcihil's Avatar
Changing the stator involves removing the engine (big job). The stators are still available, but I don't know about all the gaskets involved.
You can test the stator by cutting off the plug and testing the AC voltage between the wires. 1-2, 2-3, 3-1. You should get 60-70 volts AC between all of them.
If your not riding more than 5-10 miles, you may be able to get home with a fully charged battery, but that's cutting it close.
2012 GL1800
bcihil is online now
post #5 of 26 (permalink) Old 03-10-2019, 09:35 AM
W1ngin1t's Avatar
Isn’t there an alternator modification kit for this model year to do away with the stator?
Mark
2018 Goldwing Tour DCT Candy Ardent Red
'07 Trekker DL185 Trailer
AMA Member
DSi # 563 IDMWT #14
Riding soothes my soul.....
W1ngin1t is online now
post #6 of 26 (permalink) Old 03-10-2019, 06:15 PM
detdrbuzzard's Avatar
Quote:
i'm not sure if you can still buy the kit but you can make one yourself. I like 1200 wings but would not buy another one that didn't already have an alternator kit on it
you can send don an email and see if he still offers the kit
[email protected]
W1ngin1t likes this.
'75cb750k '05sunL 70
'79cb750f '93 gl1500 se
'79 super K '85 cb450 sc
'11 GSA
'06 mighty ST1300a
~ william ~
IDMWt #13
ama
GWOF iba with timS #03
iba 58509
mile eater
hat
moa
detdrbuzzard is online now
post #7 of 26 (permalink) Old 03-11-2019, 08:51 PM
TmDILL's Avatar
Before doing anything, see if the contacts in the connector are tight when plugged in. You could just have the connectors arcing which causes heat and a burned connector. Years ago, my uncle had a 1200 and he spliced in an extra wire to each wire inside the connector and the heat went away. The way he did it was to use same color wires and soldered them to both sides of the connectors wires. This created two connectors doing the same as one but sharing the load in parallel.
Terry Dill of San Antonio
It's not the destination, but the getting there.
TmDILL is online now
post #8 of 26 (permalink) Old 03-12-2019, 03:53 AM Thread Starter
Member
Kilt Guy's Avatar
[email protected]
I tried the email address and it came back as no good.
post #9 of 26 (permalink) Old 03-12-2019, 03:57 AM Thread Starter
Member
Kilt Guy's Avatar
Quote:
Once I get the bike home I will check it out better. If there is a fix that does not require me pulling the engine you can bet I will try it. If it is the connection that is causing the heat I can also look at replacing the entire unit with another,
post #10 of 26 (permalink) Old 03-13-2019, 01:48 PM
budoka's Avatar
Garage
If you redo the wiring/connector, be sure to insulate and shrink wrap it.
Daryl
budoka is offline
Linear Mode Linear Mode
