plug and play power socket - Page 2 - Honda Goldwing Forums
 4Likes
post #11 of 18 (permalink) Old 02-03-2019, 07:17 AM Thread Starter
fmc
Member
Thanks Jinx
fmc is online now
post #12 of 18 (permalink) Old 02-03-2019, 07:29 AM
bcihil's Avatar
If you are going to run a wire from the battery area, I would use a relay triggered by the aux connections on the fuse box. The aux fuse is only a 5 amp. Using a relay, you connect the actual power line to the battery and use the aux power to trigger the relay. This way you are not limited to the 5 amp fuse. Just fuse the power line separately. You can also add a fuse block to the output of the relay. This will allow you to add more accessories later.
As for fishing the wire, I have a piece of 1/4 inch polyethylene tubing as the fish tape.
Jinx likes this.
2012 GL1800
bcihil is online now
post #13 of 18 (permalink) Old 02-03-2019, 08:48 AM
budoka's Avatar
Garage
As mentioned it's only 5 amps. Be certain to not load it with more than that.
Daryl
budoka is offline
post #14 of 18 (permalink) Old 02-06-2019, 11:26 AM
Junior Member
tiger33771@gmail.com's Avatar
Garage
On my 2008 Airbag, there is like a plug & play on the left side pocket and it was very easy to install a cigarette lighter/ power supply.
post #15 of 18 (permalink) Old 02-17-2019, 07:59 AM Thread Starter
fmc
Member
I am going to use my battery charge cable 2 wire to extend to right side faring
fmc is online now
post #16 of 18 (permalink) Old 02-17-2019, 08:04 AM
bcihil's Avatar
Quote:
That connector is fused at 5 amps by the aux fuse.
2012 GL1800
post #17 of 18 (permalink) Old 02-17-2019, 10:12 AM
Junior Member
Garage
Sorry I missed that. I Have a 2008 GL 1800 Airbag.
One question: Did anyone had to work on the right side wires inside the trunk to fix the trunk lock? When I use the remote control the lights are flashing but the trunk doesn't unlock or lock. I did the key fob reset but nothing change.
Thanks for any suggestions.
post #18 of 18 (permalink) Old 02-17-2019, 10:44 AM
Jinx's Avatar
Does the trunk lock manually or with the key ? Do you get the trunk open symbol in the dash when the trunk is closed and/or open ?
If you close the latches manually with the trunk open , use a tool to close the latches , does the remote unlatch / activate them ?
Sorry for so many questions just need more info .
2017 Red Level 3
2006 Titanium Level 3
Traxxion suspension
WBRA senior member
IBA member 30028
IDMWT #100
"People who say it cannot be done should not interrupt those who are doing it."
George Bernard Shaw
Jinx is online now
Linear Mode Linear Mode
