Touchy throttle - Page 2 - Honda Goldwing Forums
 8Likes
post #11 of 15 (permalink) Old 06-16-2018, 02:24 PM Thread Starter
Junior Member
johnusmcret's Avatar
Garage
Quote:
Originally Posted by jcsouders5464 View Post
Did you drop it. Or did you lay it over. If you dropped you may want to claim your IDMWT #
Define please. Slow speed maneuver around my car in the driveway. Stupidly I hit the brake while leaning. I couldn't hold it more than a second or two. Gravity won.
John
'16 GL1800A
johnusmcret is online now
post #12 of 15 (permalink) Old 06-16-2018, 02:29 PM Thread Starter
Junior Member
Garage
So I removed most of the slack from the cable as advised. There might be a slight more left, but I am almost to the end of the travel of the adjuster nut. It makes a big difference.
My problem isn't starting out. I find it smoother starting off in first (or second) than it is shifting into higher gears on the fly. Again, I think this is something I will just have to practice. I do find that if I ease the clutch out it makes a smoother shift, but I am afraid this will wear out the clutch sooner than necessary??? I feel like a teenager again when first learning to drive a standard transmission in my dad's Pinto wagon!
Thanks for the advice.
John
'16 GL1800A
post #13 of 15 (permalink) Old 06-17-2018, 11:17 AM
Junior Member
Sgtgrantham's Avatar
I was beginning to think I had a problem. I purchased mine used. I also notice sometimes there is a little bog down like it’s flooding when trying to drive at slow speeds. RPM are ok and not choking down but seems like it is. Cruse works better than trying to control speed by throttle.
Sgtgrantham is offline
post #14 of 15 (permalink) Old 06-17-2018, 11:40 AM
bcihil's Avatar
Quote:
Originally Posted by Sgtgrantham View Post
I was beginning to think I had a problem. I purchased mine used. I also notice sometimes there is a little bog down like itís flooding when trying to drive at slow speeds. RPM are ok and not choking down but seems like it is. Cruse works better than trying to control speed by throttle.
the second Gen wings have a inherent problem when cold. The engine hesitates at low RPM.
You could try to reset the ECM:
Start the bike cold, and let it idle until the fans turn on without touching the throttle. This may take a while, be patient. Then shut the bike off and see if it helps.
Chopin likes this.
2012 GL1800
bcihil is online now
post #15 of 15 (permalink) Old 06-17-2018, 11:43 AM
bcihil's Avatar
There is a second adjustment nut on the cable located up under the faring. You should be able to see it by looking up toward the left fork
2012 GL1800
Linear Mode Linear Mode
