Gushing Carb Leak - Honda Goldwing Forums
 2Likes
post #1 of 16 (permalink) Old 10-31-2017, 12:55 PM Thread Starter
Junior Member
Gushing Carb Leak
Recently ‘inherited’ an ‘84 GL1200 Aspencade that has been sitting for at least 5-6yrs. Still in great condition, garage kept, and (seemingly) runs great.
The only problem so far is that it has a gushing fuel leak behind the right side carbs. This side sits further forward than the left, so, of course, I can’t see a darn thing to be able to pinpoint “where” and the “big manual” I bought is practically useless.
Any ideas, theories, and/or advice?
usmc5811 is offline
post #2 of 16 (permalink) Old 10-31-2017, 01:52 PM
Cantankerous's Avatar
Garage
Does it do it without the engine running with the ignition on?
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Cantankerous is offline
post #3 of 16 (permalink) Old 10-31-2017, 02:18 PM Thread Starter
Junior Member
Yes, but not with engine off/key out, only when the fuel pump is doing its job.
usmc5811 is offline
post #4 of 16 (permalink) Old 10-31-2017, 02:19 PM
Garage
I would suspect a stuck float/needle valve, especially after sitting with fuel in it.
budoka likes this.
IDMWT #23
Member #3480
post #5 of 16 (permalink) Old 10-31-2017, 02:25 PM Thread Starter
Junior Member
Just basically filling up and overflowing? I was hoping something like that but fearing something “less simple” LOL
usmc5811 is offline
post #6 of 16 (permalink) Old 10-31-2017, 02:32 PM
Garage
That's what I would suspect, but it could be a bad fuel line.
IDMWT #23
Member #3480
post #7 of 16 (permalink) Old 10-31-2017, 03:54 PM
budoka's Avatar
Garage
I had that happen on my Vulcan some years ago. A simple tap with the handle of a screwdriver and fixed it. With the carb kind of hidden might be a tad tougher though.
Daryl
budoka is offline
post #8 of 16 (permalink) Old 10-31-2017, 06:09 PM
ETC
ETC's Avatar
Garage
I see this all the time with older carb equipped bikes and also after a carb rebuild. There is some material lodged between the needle and seat on one or more carbs. This is always the first thing I do in this situation. fire up your air compressor, disconnect the fuel line at the petcock and push some air into the line. I normally set the pressure to 40 psi. Gas will flood out so be prepared. Most of the time this blows the seat clear and the problem goes away. It could take a few tries however. If this does not work then you will have to pull the carb bank and do a full cleaning.
"Take the Right Turn"
ETC is online now
post #9 of 16 (permalink) Old 10-31-2017, 09:23 PM Thread Starter
Junior Member
Quote:
Wow! Thanks for this tip/hack - if I can avoid yanking the carbs, everybody wins!
usmc5811 is offline
post #10 of 16 (permalink) Old 11-01-2017, 07:23 AM
Garage
If you're able to get the leak under control without pulling the carb bank, you might try some Sea Foam in the fuel. That will help clean the insides of the carb. Always a good idea to keep things tiddy
Tim Schutter
84 GL1200 Aspy
Freedom is not the right to do as you please; it is the liberty to do as you ought.
tschutter is offline
Linear Mode Linear Mode
