GL1800 front brake drag - Honda Goldwing Forums
 1Likes
Closed Thread
post #1 of 11 (permalink) Old 07-13-2017, 09:25 AM Thread Starter
Junior Member
Hi all,
I have an 07 GL1800 with dragging front brakes. With wheel suspended, I get about 1/4 revolution. After a short ride, with no brake use, the rotors are almost too hot to touch. The rear tire spins freely, and the brake recall has been done. The drag did not disappear with opening the bleed screws, so I concluded it was an issue with the caliper. As well, the right caliper seems worse than the left.
So, I rebuilt both calipers (new seals and pistons) and cleaned the m/c - the problem persists...
I cant see how - but can one screw up a caliper rebuild??
Any guidance would be appreciated, but if you can't fix it long distance for me, I'm never coming back.
John
CChowdher is offline
post #2 of 11 (permalink) Old 07-13-2017, 10:55 AM
NREMTP's Avatar
Garage
Welcome to the forum. Someone knowledgeable will be along shortly. I suspect you may have a warped rotor(s) or a hydraulic lock.
Bob
2012 ABS "Red Ghost"
IDMWT 65
NREMTP is online now
post #3 of 11 (permalink) Old 07-13-2017, 10:55 AM
Cantankerous's Avatar
Garage
Has there been any other work done to the bike recently, i.e new front tire?
1984 GL1200 Pearl Saturn Red/Century Brown Metallic (Sold)
1981 Honda CM400T Candy Sword Blue with Metallic Light Blue (Cubed and Recycled)
IDMWT #23
Member #3480
Cantankerous is offline
post #4 of 11 (permalink) Old 07-13-2017, 11:08 AM Thread Starter
Junior Member
@NREMTP - Rotors are true. I opened the bleed screws to see if there was hydraulic pressure - it did not seem to make any difference.
@Cantankerous - No recent work.
It seems to involve the front brake circuit...
post #5 of 11 (permalink) Old 07-13-2017, 12:23 PM
DreamWeaver's Avatar
Location: Ranch outside Bertram, TX about 80 miles north of Austin.
So, the front tire has not been removed prior to this problem. Is that correct? If the tire had been removed and replaced and then the problem started, I suspect that the two spacers on the axle have been reversed. They are of different sizes and if the one on the left gets put where the right one should be, you will have very big problems. You can get the wheel on with this reversal but you will have severe rotor and brake drag. I would check the placement of the axle spacers. ...Isaac
budoka likes this.
No river is shallow to a man that can't swim..
2007 GL 1800 (VA)
2005 Yamaha FJR 1300
Isaac
DreamWeaver is offline
post #6 of 11 (permalink) Old 07-13-2017, 12:25 PM
dsurley's Avatar
Garage
Did you clean the pin that the calipers slide on?
If the calipers do not freely float on that pin it will not let it fully retract.
When you took out the pads, was one pad of either set more worn than the other, if so, symptom of above.
Did you go through the entire brake bleed sequence in careful order? Wings are notoriously picky on the order of the brake bleeding.
IDMWT member #80
Never walk, when you can ride!
current ride : 2013 GL1800 Audio Comfort
Darkside Yokohama Avid ENVigor 195/55 R16
non-runflat
Double Darkside Bridgestone BT45 Battlax Front
Past rides: '98 GL1500SE
'03 750 Kawasaki Vulcan
'81 850 Suzuki
'80 550 Suzuki
dsurley is offline
post #7 of 11 (permalink) Old 07-13-2017, 12:38 PM Thread Starter
Junior Member
@DreamWeaver - Yes, I had considered the possibility that I flipped the tire, but the spacers are in the right spot.
@dsurley - Caliper glide pins are clean and the calipers appear to float as they should. The pads in both calipers are evenly worn on both. Yes - bleed sequence was followed - however, I am unclear how air in the system would prohibit retraction.
post #8 of 11 (permalink) Old 07-13-2017, 03:01 PM
[QUOTE=CChowdher;1970465] @DreamWeaver - Yes, I had considered the possibility that I flipped the tire, but the spacers are in the right spot.
Are you positive about this? I think the larger one goes on the drivers side and the smaller one on the passenger side. I would make sure about their placement. I have reversed them inadvertently and put everything back together and spinning the tire, caught the mistake by noting that the tire would only spin about a quarter of a turn before binding up. The spacers fall out when the tire is removed so reversing them is an easy mistake to make. I would surly check this before you go nuts on something else. ......Just a suggestion.....Isaac
2007 GL 1800 (VA)
Isaac
post #9 of 11 (permalink) Old 07-14-2017, 07:20 AM Thread Starter
Junior Member
@DreamWeaver - yes, I am sure. Confirmed with manual.
post #10 of 11 (permalink) Old 07-14-2017, 01:02 PM
Quote:
Okey Dokey, Roger Dodger, Over and out.....Isaac
2007 GL 1800 (VA)
Isaac
Closed Thread
Linear Mode Linear Mode
