m/c gel pad vs walmart gel pad - Honda Goldwing Forums
http://www.goldwingowners.com/forums
» Insurance
» Sponsors
Go Back   Honda Goldwing Forums > Goldwing Motorcycle Discussion Forums > Honda Goldwing Forum General Discussion
Old 09-03-2011, 10:37 AM   #1
detdrbuzzard
detdrbuzzard's Avatar
Default m/c gel pad vs walmart gel pad
last night i took off for walmart to get a couple gel pads, had to make the 40 mile ride to bellville, mi to get them but it ride was ok with the high humidity it felt pretty good. i had seen the gel pads at the bellville walmart before but i was being to cheep at the time to get them. i went out this morning and took the m/c gelpad off and put it in the trunk and put the walmart gelpad on. just looking at it it is wider, cause its made for a car seat and thinner. i took schafer south to ford rd. ( m-153 ) and m-153 west to hines drive. usually i would have ridden hines drive a dozen times by now but this is only my third time in the park this year, it a nice senic ride. hines drive ends in northville, mi and i made a right turn on 7 mile rd going east and took it to I-275 south, back to I-96 east and to schafer going south back home. so i have a mix of riding. i found the walmart gelpad to be comfortable but needs to be trimmed to fit the seat better and i like the height of the m/c gelpad better
__________________
'75cb750k
'79cb750f
'79cb750 super K
'84 gl1200 aspencade
'93gl1500se,
'85 cb450sc
'05 sunL 70
~ william ~
IDMWt #13
gwrra
ama
iba 58509
hat
detdrbuzzard is online now   Reply With Quote
Old 09-03-2011, 10:55 AM   #2
budoka
budoka's Avatar
Default
What's the brand of the m/c one?
__________________
"Racing improves the breed..." Soichiro Honda
current rides: '09 GL1800AD "SENSHI"; 2003 RVT1000r (RC51) "BUSHI"... certified m/c addict. IDMWT #12. GWRRA #028890
budoka is offline   Reply With Quote
Old 09-03-2011, 11:01 AM   #3
Ron Robertson
Lifetime Premium
Ron Robertson's Avatar
Default
I have double padded the WalMart seat and cut a U shape section out of the pads in vipper end/front of the seat, so it lay flatter over the rise of the front of the seat. Right now I'm using my Air Hawk, but switch them out once in a while to get a little different fit.
From the Northwest Corner
Ron
Ron Robertson is online now   Reply With Quote
Old 09-03-2011, 11:17 AM   #4
detdrbuzzard
Default
Quote:
i got the m/c gelpad here http://www.amspecialtiesusa.com/
__________________
'75cb750k
'79cb750f
'79cb750 super K
'93gl1500se,
'85 cb450sc
'05 sunL 70
~ william ~
IDMWt #13
gwrra
ama
iba 58509
hat
Old 09-03-2011, 06:03 PM   #5
bearandladybear
Member
Default walmart gel pad
Have had no luck finding any gel seats at our local walmart does anyone know if this a US product only?
Is there an alternative without going on an Airhawk?
__________________
it's not the destination, but the journey
bearandladybear is offline   Reply With Quote
Old 09-03-2011, 06:50 PM   #6
Ridefree
Member
Default
I bought two walmart gel pads and it does make the stock seat more comfortable, but I think the added height has more to do with it for me. I may pick up another tonight and try three, as I have no problem flat footing with two. They are taking away that crotch rocket feel on my legs.
This is just a temporary fix till this winter when I will probably order a daylong saddle. Those have been the best seats for me in the past.
__________________
2004 GL 1800
1997 Valkyrie
Ridefree is offline   Reply With Quote
Old 09-03-2011, 11:33 PM   #7
GoldDigger
GoldDigger's Avatar
Default gel pads
I put one of the swoosh gel pads under the WM gel pad and it works great for me. Just came off of a 1500 mile weekend ride and it did great. The thing I like is putting me a little higher. I lets me stretch my legs out on my pegs which saves my back. Warning, don't forget to turn the pads over when you get off for a while...they do get hot, especially in this 102 degree TX heat.
__________________
CMA #146086
'08 Navi 1800
'98 Aspencade,
'02 Shadow 1100
Patriot Guard Rider
GWRRA Chapter MS-L
Jeremiah. 29:11
God says, "I have plans to prosper you, not to harm you..."
GoldDigger is online now   Reply With Quote
Old 09-04-2011, 10:00 AM   #8
detdrbuzzard
Default
i took the same ride this morning that i took yesterday, only difference was i put both walmart gelpads in one container. it was very coushie and for taller riders it gets the bend out of those knees even more than my m/c gelpad. but looking at the walmart gelpad gave me an idea and i'll tell ya what i did later
__________________
'75cb750k
'79cb750f
'79cb750 super K
'93gl1500se,
'85 cb450sc
'05 sunL 70
~ william ~
IDMWt #13
gwrra
ama
iba 58509
hat
Old 09-04-2011, 12:36 PM   #9
Cantankerous
Cantankerous's Avatar
Default
Quote:
Uh Oh..........
__________________
Current Ride.
1988 GL1500/6 Martini Beige Metallic
Previous rides.
1993 GL1500 SE
1984 GL1200 Aspencade (X2)
1981 CM400T
1976 KE125
IDMWT #23
Member #3480
Cantankerous is offline   Reply With Quote
Old 09-11-2011, 09:20 AM   #10
detdrbuzzard
Default
last night it was warm and the humidity made it feel even warmer so after getting of the forum i decided that i would take a ride. it had been raining most of the day amd my bike cover isn't exactly water proof and some rain made its way onto my new walmart gelpad. after letting as much water as i could drain from it i still had a wet seat so i took my m/c gelpad and put it on top of the walmart gelpad and it was 25 miles of comfort. the m/c gelpad is one solid piece and i was thinking of cutting the " H " pattern in it so it would move like the walmart gelpad does but now i think i'll trim the walmart gelpad to fit my seat better and use the scraps in the m/c gelpad
__________________
'75cb750k
'79cb750f
'79cb750 super K
'93gl1500se,
'85 cb450sc
'05 sunL 70
~ william ~
IDMWt #13
gwrra
ama
iba 58509
hat
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
