BikeMP3 frustration - Honda Goldwing Forums
http://www.goldwingowners.com/forums
» Insurance
» Sponsors
Go Back   Honda Goldwing Forums > Goldwing Motorcycle Discussion Forums > Honda Goldwing Forum General Discussion
Old 05-23-2011, 08:33 PM   #1
BARNSTORMER
Junior Member
BARNSTORMER's Avatar
Default BikeMP3 frustration
I installed the BikeMP3 on my 2007 Audio. I am trying to load SD card(s) from my Windows media library. I started with a brand new 8GIG card, synced several albums to it, inserted it into the BikeMP3 and the player can not find the music. The card will play back on my computer. Same result with a 4GIG card and a 2GIG card. I have two old 256MB cards from digital cameras, I can sync to them and they will play on the BikeMP3 player. So-o-o-o I have two 256 cards with some tunes that work for now.
Anyone have an idea why the 256MB cards will work, but the larger capacity cards won't?
BARNSTORMER is offline   Reply With Quote
Old 05-24-2011, 01:40 AM   #2
Wing Down Under
Wing Down Under's Avatar
Default
The SD cards that you have are they single density or double density compared to the 256mb cards.
__________________
Like a great man once sang in his song Quote " Life is whats happening to you while your busy making other plans ".
Wing Down Under is offline   Reply With Quote
Old 05-24-2011, 11:47 AM   #3
gto49us
Junior Member
gto49us's Avatar
Default
Hi Barnstormer:
You didn't say if your unit was new or used. I checked their website (http://www.bikemp3.com/GL1800-Digita...GW-IPD-V03.htm) and it looks like they had issues with some of their older units.
According to the website, the unit accepts SD cards up to 8GB. Folders must be numbered (1, 2, etc.) and contain up to 99 songs in each folder. The number of folders on the SD card will depend on the model of your bike.
I would check the formatting on the 256 MB cards vs. the larger capacity cards. Perhaps try reformatting one of the larger cards and putting only a couple of folders on it with your music (identical to the 256 MB cards).
If the larger cards still won't work, your unit may require a firmware upgrade to recognize the larger capacity cards. At any rate, it would be a good idea to contact the manufacturer regarding your problem. They will likely have a quick fix for you.
__________________
Ron Hofman
2006 GL1800 Navi/Comfort
http://mb-a.regionk.ca/
http://www.pbase.com/gto49
gto49us is offline   Reply With Quote
Old 05-28-2011, 09:17 AM   #4
BARNSTORMER
Junior Member
Default
Well, I have "sort of" solved my situation. I have figured out a couple things: 1)If you use a 4GIG or larger SD card Windows Media wants to do an automatic sync when you click on sync, and I just could not figure out how to switch it to manual sync. 2)On any SD card you have to click on the sync down arrow, click on "more options", click on your device, and uncheck "create folder heirarchy on device". This has to be done because the BikeMP3 player will not read folders, only CD tracks.
I am using 2GIG SD cards, syncing about 140 tracks onto a card.The Gold Wing CD changer system will only go up to 99 tracks. On mine after it hits 99, it then goes to a second track 1, will go up to about 41 then rotate back to the "first" track 1, all the time showing CD1.
Summary:
I did not purchase the "song populating" software, had trouble trying to download it.
I am using 2GIG cards, can load about 140 tracks on a card, not using full capacity. That is still a lot of music.
Cards must be set up to not "create folder heirarchy".
Reproduction (sound) is great and cost is much less than OEM 6 disc changer.
Oh,yeh---I have a couple old 256 MB cards from early digital cameras, will load some speciaty music on them, like Christmas or patriotic music. Don't ride much in Indiana around Christmas time, but you never know.
Mel
Old 07-01-2011, 02:14 PM   #5
K7TTY
Junior Member
Default Music Player Software Download Alternate Site
Software can be downloaded from the alternate site maintained by the software developer/creator at http://k7tty.com/motorcycle/download/index.htm. This is also where you can get the latest version. You will still need the passkey from Wingstuff to unlock the trial version mode. The trial version mode allows you to try out the software before purchasing it to see if it meets your needs.
K7TTY is online now   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
