CB radio error - Honda Goldwing Forums
http://www.goldwingowners.com/forums
» Insurance
» Sponsors
Go Back   Honda Goldwing Forums > Goldwing Motorcycle Discussion Forums > Honda Goldwing Forum General Discussion
Old 01-09-2009, 05:49 PM   #1
Schouveller
Junior Member
Default CB radio error
I get a CB error message and must turn it off to reset it. Does anyone no why this happens
Schouveller is offline   Reply With Quote
Old 01-10-2009, 02:01 PM   #2
Johnny R
Member
Johnny R's Avatar
Default
First time I heard of this problem. Done any wiring lately for headsets or something?
__________________
Johnny R.
1989 GL1500 - I'm pleased as punch, coast to coast!
2011 Malibu LS - Great winter wheels!
Johnny R is offline   Reply With Quote
Old 01-23-2009, 07:25 PM   #3
tex1960
Junior Member
Default
just installed cb in my 03,started bike,turned on cb and [cb error] came up on display,need help . tex1960
tex1960 is offline   Reply With Quote
Old 01-30-2009, 09:36 PM   #4
fort davis bound
Junior Member
Default CB Error
I got an 05 & CB error happen all the time. No one can tell what is wrong.
fort davis bound is offline   Reply With Quote
Old 01-31-2009, 12:21 AM   #5
tex1960
Junior Member
Default
I Got My Cb Error Fixed Had Plugedin Wrong, Oops . Now If This Snow Would Only Melt.
Old 08-01-2010, 02:06 PM   #6
salyzyn
Junior Member
Default
Check and clean all the following:
1) CB antenna ground
2) AM/FM antenna ground (this is where the Audio Unit gets it's strongest ground connection)
3) CB 3-pin Hitachi-style power plug underneath the seat
4) CB 13-pin Sumitomo interface connector underneath the shelter near the right 'meter' panel.
Make sure you have as close to 1:1 match on your CB antenna, for otherwise there will be antenna currents in all the bike's wiring when you transmit and could also lead to a CB Error report. To measure this requires an appropriate SWR meter and cable adapters.
A CB Error occurs when the CB indicates it is installed, and it fails to provide a clean digital protocol serial communications packet back to the Main Audio Unit. Since the digital signals are ground-referenced, the most likely causes of the protocol failure are related to any of the several ground-points that the CB and Audio Unit utilize, or resistance through the connectors that lead between the units.
salyzyn is offline   Reply With Quote
Old 05-12-2012, 04:57 PM   #7
wing trike
Junior Member
Default Cb radio error
I also have the error message, Brand new 2012 goldwing,Viper trike, dealer does not seem to know what is wrong???? The trouble seems intermittent, HARD TO FIND, Error message only starts in transmit mode, clears with power reset, Dealer put in a new ground system, Viper trike is a new setup, lots of fiberglass, A good ground may be a problem
wing trike is online now   Reply With Quote
Old 05-12-2012, 06:17 PM   #8
budoka
budoka's Avatar
Default
Just checked the service manual and can't find diddly on the CB error. There must be something in the stuff (papers/installation instructions) that comes with the CB if it isn't one of the connections.
__________________
A man can have many names and wear many hats, but he only has one true nature.
current rides: '09 GL1800AD "SENSHI"; 2003 RVT1000r (RC51) "BUSHI"... certified m/c addict. IDMWT #12. GWRRA #028890
budoka is offline   Reply With Quote
Old 05-12-2012, 06:40 PM   #9
salyzyn
Junior Member
Default
Quote:
No mention of CB error in the service manuals or documents.
It is a direct result of a protocol hickup over the serial communication lines, which are single ended and prone to noise pickup. Power fluctuations will do this too. The procedure that results in fixing this is always cleaning the connectors (do NOT use dielectric grease, these are low-current signals) to the CB, and to make sure the ground is solid (including at the antenna brace). The CB error can be triggered by Transmit as well, so one needs a good match to the Antenna too.
Old 05-12-2012, 10:35 PM   #10
joe in calif
joe in calif's Avatar
Default
Thisa is on thr 01 to 05, in 06 and up Honda moved that plug to next to the black key panel that opens the right fairing pocket.
Most CB error messages are because of a loose connection.
__________________
joe in calif is online now   Reply With Quote
You may not post new threads
You may not post replies
Forum Jump
Powered by vBadvanced CMPS v3.2.2
Motorcycle News, Videos and Reviews
Honda Grom Forum Harley Davidson Forum Honda 600RR Forum Kawasaki Forum Yamaha R6 Forum Yamaha FZ-09 Forum
1199 Panigale Forum Roadglide Forum Honda CBR1000 Forum Vulcan Forum Yamaha R1 Forum Yamaha R3 Forum
Ducati Monster Forum Harley Forums Honda CBR250R Forum ZX10R Forum Star Raider Forum Yamaha Viking Forum
Suzuki GSXR Forum V-Rod Forums Honda Shadow Forum Kawasaki Motorcycle Forum Star Warrior Forum KTM Duke 390 Forum
SV650 Forum BMW S1000RR Forum Honda Fury Forum Kawasaki Versys Forum Drag Racing Forum Ducati 899 Panigale Forum
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes BMW NineT Forum
Volusia Forum BMW F800 Forum Triumph 675 Forum MV Agusta Forum HD Street Forum Suzuki GW250 Forum
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
