How often to change spark plugs? - Honda Goldwing Forums
post #1 of 15 (permalink) Old 12-31-2010, 04:06 PM Thread Starter
GoldDigger's Avatar
Have a '98 Aspy with 127K and don't know the history. Running good, no miss but only appx. 36 mpg. Thought maybe new plugs would help the mpg. What say ye? Which plugs do you recommend.
CMA #146086
'08 Navi 1800
'98 Aspencade,
'02 Shadow 1100
Patriot Guard Rider
GWRRA Chapter MS-L
Jeremiah. 29:11
God says, "I have plans to prosper you, not to harm you..."
GoldDigger is offline
post #2 of 15 (permalink) Old 12-31-2010, 04:21 PM
Two Wheel Wing's Avatar
35 to 40 mpg is about the average with a 1500. Some get more, some less depending on your driving habits. So you are in the range. I sure it would not hurt to throw a set in, but then again, if it ain't broke...... Your choice. Ride safe..
Charlie
IDMWT #1
2009 GL1800 Silver Audio/Comfort
Faith is more than believing God can, it's knowing God will.
The government cannot give to anybody anything that the government does not first take from somebody else.
Mountaintops are for views and inspiration, but fruit is grown in the valleys
Two Wheel Wing is online now
post #3 of 15 (permalink) Old 12-31-2010, 04:31 PM
After doing some searches some guys say they are getting 40-50k from a set of plugs. Seems a little high to me, but that's what I found.
Charlie
IDMWT #1
post #4 of 15 (permalink) Old 12-31-2010, 04:32 PM
Lifetime Premium
Ron Robertson's Avatar
I've been using NGK5129 DPR7EA-9 it's the same as the OEM plug. I change them every 30,000 miles or so. I always have a couple sets in the shop, if the mod strikes I change them sooner.
If you haven't already you might want to change the fuel and air filters while you are at it. Then you know where you are. Just a thought.
From the Northwest Corner
Ron
Ron Robertson is online now
post #5 of 15 (permalink) Old 12-31-2010, 07:29 PM Thread Starter
GoldDigger's Avatar
Ron, I have K&N air filter and have just cleaned and reoiled it. Where is the fuel filter?
CMA #146086
'08 Navi 1800
'98 Aspencade,
'02 Shadow 1100
Patriot Guard Rider
GWRRA Chapter MS-L
Jeremiah. 29:11
post #6 of 15 (permalink) Old 12-31-2010, 08:09 PM
whacker's Avatar
fuel filter can be seen from the fuel access door, easily changed when the false tank is off.
whacker is offline
post #7 of 15 (permalink) Old 12-31-2010, 08:14 PM
Lifetime Premium
Golddigger:Whacker is right. You have take the seat and the false tank/radio/gas door, unit off.
Here is a tip that might save you some grief when changing the fuel filter. In the past I've found some that have a tiny sharp little ridge on the input and output fitting it runs the length of the tube, you can easily feel it, it is the result of injection molding in manufacturing. Use some fine sand paper and remove all of it. I know of at least three bikes that have leaked gas because of this, simply sanding the edge off solved the problem
Ron
post #8 of 15 (permalink) Old 01-01-2011, 09:00 AM Thread Starter
GoldDigger's Avatar
I don't know what you are calling the "false tank" please explain a little further.
CMA #146086
'08 Navi 1800
'98 Aspencade,
'02 Shadow 1100
Patriot Guard Rider
GWRRA Chapter MS-L
Jeremiah. 29:11
post #9 of 15 (permalink) Old 01-01-2011, 09:49 AM
Cantankerous's Avatar
Garage
They are the plastic pieces that are below the radio. They are in place of the fuel tank seen on older/smaller bikes.
IDMWT #23
Member #3480
Cantankerous is offline
post #10 of 15 (permalink) Old 01-01-2011, 10:55 AM
Lifetime Premium
Gold Digger: It the thing that cover the Air Filter box, it has the Am/Fm radio, tape player and the door to the gas cap. You had it off when you cleaned your air filter.
On ever 1500 I've worked on you have to remove the seat to get at the two acorn nut that hold the back end of the unit down, there are also two levers inside the gas filler door that have to be moved forward to release the unit from the bike. Also be sure to remove the plastic filler that are attached to the unit that act as fillers around the fork tunnel.
Happy New Year to you.
Ron
Human Verification
Linear Mode Linear Mode
