Has anyone had a problem with the gas cap lock not turning? My buddy has a 2005 1800r and he can't get the cap off. The key won't turn at all. Pushing down on the cap doesn't help. We sprayed some liquid graphite and that didn't help. This has been going on for quite a while now and it always eventually opened. Today, no luck. Two different keys didn't help either. Is it time for a dealer/locksmith visit?
It seems like the key is going all the way in. We used two different keys with no luck. Both work in the ignition but......I had the same thought as you. We tried to take the "dash" off of the tank but the cap needs to be removed to do that.
If I'm remembering correctly ?????? On my 1300 the gas cap had to be depressed along with turning the key. Those two spring loaded catches may need a bit of lube once you get it out. I do recall that I put one of those leather tank bibs on and that caused me to depress the cap more to get it to latch in the hole.
Anyway, it's now fixed. Dealer wanted $110 for a new one. They woudn't help get the old one off though. Locksmith wanted $150 to drill it out to get it off. Called another locksmith and he said bring the bike in. He used the key and WD40 and kept working it for about 45 minutes. Finally it started to turn. After it released and came off he took it apart and cleaned it and put it back together. Works like a charm now. Total cost? $10...turned out to be a great day.
Related Threads
Honda Goldwing Forum
511.5K posts
21.4K members
Since 2008
