Need help with FI indicator... - Honda Goldwing Forums
post #1 of 9 (permalink) Old 05-11-2011, 03:44 PM Thread Starter
Junior Member
Post Need help with FI indicator...
Hi All,
Could please somebody help with FI problem?
My dad has a GL1800 (got it from USA last year) and when out riding the FI light is coming on after a while. He can also notice a wee lack of power. After switching off ignition and restarting engine light is out but after some time it turns on again. He noticed that it's taking shorter for light to turn on when temperature outside is higher.
I spent last few days on internet and reading Manual and spoke with him about reading error codes but the thing is that when he put on neutal and put side stand down bike just cut out. I sked him to doubble check but Bike was not in a gear.
I can't find any information what to do in this case...
All help will be most apprieciated!!!
Thank you,
Lasaria
Lasaria is offline
post #2 of 9 (permalink) Old 05-11-2011, 08:42 PM
trike lady's Avatar
Garage
The IAT or Intake Air Temperature Sensor may be bad or out of spec.
Check the gear position sensor.
IDMHT#1
I.M.B.B.A. Technician II Certification
trike lady is offline
post #3 of 9 (permalink) Old 05-12-2011, 02:25 PM
you must have motorcycle scanner to pull codes from computer
2003 GL1800 POLICE is offline
post #4 of 9 (permalink) Old 05-12-2011, 05:55 PM
trike lady's Avatar
Garage
What year is the Wing in question?
If you have the service manual, pull the IAT and test it to see if it is within spec as per the manual.
IDMHT#1
post #5 of 9 (permalink) Old 05-12-2011, 06:44 PM
budoka's Avatar
Garage
AS 2003 says, you need the Honda digital diagnostics to identify the code(s) stored in the bike's computer. Not sure if you can check th IAT as trike lady suggests without the link-up. What year is the 1800? It should still be under factory warranty if it's an '08 or newer; got a VIN#? I can see if I can access it through my system.
Daryl
budoka is online now
post #6 of 9 (permalink) Old 05-12-2011, 07:01 PM
trike lady's Avatar
Garage
If it's an 01-03 you can use a jumper wire.
If you isolate the component from the system you can test it. I've tested O2 sensors off the bikes and found out if they are with in spec.
04 and newer I have an SCS and an H685.
In the service manual you can check the resistance of the IAT off line (2001-2005 p5-23) may possibly be checked the same way for resistance on newer models.
IDMHT#1
post #7 of 9 (permalink) Old 05-12-2011, 10:34 PM
trike lady's Avatar
Garage
The codes for the PGM-FI
If the FI light (Programmed Fuel Injection (PGM-FI) Malfunction Indicator Light (MIL)) comes on pull over but DO NOT shut bike off. Put in neutral and put side stand down, RPM’s below 1500. This signals the ECM to send the error code to the MIL. Count the number of long and short flashes. This will give you the error code.
If you shut the bike off the error code is lost - sort of. It will be retained in the ECM but it is harder to get out. If the bike stops and then will not restart you can get the FI light to flash the error code by cranking the engine for 10 seconds. The FI light will then flash the error code.
Long Blink = 10 Short Blink = 1
i.e. long long long short short short = 33 check error code 33
Number of MIL blinks. Symptoms and cause
0 No blinks • Engine does not start
• Open circuit in the power input and ground wires of the ECM: • Faulty bank angle sensor
• Open circuit in bank angle sensor related wires: • Faulty FI IGN relay: • Open circuit in FI IGN relay related wires
• Faulty engine stop switch: • Open circuit in engine stop switch related wires: • Faulty ECM: • Blown FI IGN fuse (20 A)
• Blown ST. KILL fuse (10 A):
0 No blinks • Engine operates normally
• Open circuit in MIL wire: • Faulty combination meter: • Faulty ECM
0 Stays lit • Engine operates normally
• Short circuit in service check connector wire: • Short circuit in MIL wire: • Faulty ECM
1 Blinks • Engine operates normally
• Loose or poorly connected MAP sensor connector: • Open or short circuit in MAP sensor wire: • Faulty MAP sensor
7 Blinks • Hard to start at a low temperature (ECM controls using preset value; coolant temperature: 85 C/185 F)
• Loose or poorly connected ECT sensor connector: • Open or short circuit in ECT sensor wire: • Faulty ECT sensor
8 Blinks • Poor engine response when operating the throttle quickly (ECM controls using preset value; throttle opening: 0 )
• Loose or poorly connected TP sensor connector: • Open or short circuit in TP sensor wire: • Faulty TP sensor
9 Blinks • Engine operates normally (ECM controls using preset value; intake air temperature: 28 C/82 F)
• Loose or poorly connected IAT sensor connector
• Open or short circuit in IAT sensor wire: • Faulty IAT sensor
10 Blinks • Engine operates normally at low altitude
• Engine idles roughly at a high altitude (ECM controls using preset value; barometric pressure: 760 mm Hg/1,013 hPa)
• Loose or poorly connected BARO sensor connector: • Open or short circuit in BARO sensor wire: • Faulty BARO sensor
11 Blinks • Engine operates normally
• Loose or poorly connected vehicle speed sensor connector
• Open or short circuit in vehicle speed sensor wire: • Faulty vehicle speed sensor
12 Blinks • Engine does not start
• Loose or poorly connected No. 1 injector connector: • Open or short circuit in No. 1 injector wire: • Faulty No. 1 injector
13 Blinks • Engine does not start
• Loose or poorly connected No. 2 injector connector: • Open or short circuit in No. 2 injector wire: • Faulty No. 2 injector
14 No blinks • Engine does not start
• Loose or poorly connected No. 3 injector connector: • Open or short circuit in No. 3 injector wire: • Faulty No. 3 injector
15 Blinks • Engine does not start
• Loose or poorly connected No. 4 injector connector: • Open or short circuit in No. 4 injector wire: • Faulty No. 4 injector
16 Blinks • Engine does not start
• Loose or poorly connected No. 5 injector connector: • Open or short circuit in No. 5 injector wire: • Faulty No. 5 injector
17 Blinks • Engine does not start
• Loose or poorly connected No. 6 injector connector: • Open or short circuit in No. 6 injector wire: • Faulty No. 6 injector
18 Blinks • Engine does not start
• Loose or poorly connected camshaft position sensor connector
• Open or short circuit in camshaft position sensor wire: • Faulty camshaft position sensor
19 Blinks • Engine does not start
• Loose or poorly connected ignition pulse generator connector:
• Open or short circuit in ignition pulse generator wire: • Faulty ignition pulse generator
21 Blinks • Engine operates normally
• Open or short circuit in right O2 sensor wire: • Faulty right O2 sensor
22 Blinks • Engine operates normally
• Open or short circuit in left O2 sensor wire: • Faulty left O2 sensor
23 Blinks • Engine operates normally
• Open or short circuit in right O2 sensor heater wire: • Faulty right O2 sensor
24 Blinks • Engine operates normally
• Open or short circuit in left O2 sensor heater wire: • Faulty left O2 sensor
25 Blinks • Engine operates normally
• Loose or poorly connected right knock sensor connector: • Open or short circuit in right knock sensor wire: • Faulty right knock sensor
26 Blinks • Engine operates normally
• Loose or poorly connected left knock sensor connector: • Open or short circuit in left knock sensor wire: • Faulty left knock sensor
29 Blinks • Engine stalls, hard to start, rough idling
• Loose or poorly connected idle air control (IAC) valve connector: • Open or short circuit in IAC valve wire: • Faulty idle air control valve
33 Blinks • ECM does not hold the self diagnostic data
• Faulty E2-PROM in ECM • Engine operates normally
41 No blinks • Engine operates normally
• Loose or poorly connected connector in gear position switch related circuits
• Open or short circuit in gear position switch wires: • Faulty gear position switch: • Faulty clutch switch: • Faulty side stand switch
This list was found on the net.
IDMHT#1
post #8 of 9 (permalink) Old 05-13-2011, 02:18 PM Thread Starter
Junior Member
Thank you all very much for advices!!! It's most apprieciated!!!
Wing is from 2008 (VIN 1HFSC47LX8A704080) but I'm affraid servicing it will be a wee bit tricky as it was in an accident in America, still broken shipped to Poland, repaired and then bought by my Dad.
He told me that Air Filter cover on right side is not original (it was adapted from left side cover) so IAT idea seems right. This would explain why when outside is worm FI lights up sooner than in colder weather.
I'll work with my Dad and manual in this same time and we will check this IAT :0)
He will really have to start completing original parts and have general check as he plans trip around a Europe in September!
Thank you very much for your help one more time!
Lasaria is offline
post #9 of 9 (permalink) Old 05-13-2011, 06:11 PM
budoka's Avatar
Garage
Tried the vin anyway Lasaria, but my data base doesn't include US registered units. Sorry
Daryl
Human Verification
Linear Mode Linear Mode
