Spark Plug Question - Honda Goldwing Forums
post #1 of 10 (permalink) Old 01-17-2011, 09:53 AM Thread Starter
Grandy's Avatar
Spark Plug Question
Looking at the service manual it seems spark plug replacemant is fairly straight forward.
Is there anything to look out for or "trick of the trade" for someone who is mildly mechanic, (just out of practice)?
** IDMWT # 34 **
1964 Honda 90 C200, 1964 BSA 650 Hornet,
1965 Bultaco 175 Mercurio, 1968 Honda CB450,
2008 Honda Shadow 750, 2006 Honda GL1800 Navi,
2006 GL1800 W/2010 CSC trike - (SR-71 "Edje")
Grandy is offline
post #2 of 10 (permalink) Old 01-17-2011, 10:33 AM
chrisgl1800's Avatar
The new machines are so efficient with their electronics now, the spark plugs seem to be a lost art. The primary thing I would say do, is tho put a small amoujt of "anti seize" on each plugs threads to make sure that since they are in the engine so long before checking or changing, that will keep them from ruining an aluminum head. You could "degree" them, but that is an unnecessary performance thing they do to maximize fuel burn.
Also, don't pull on the plug wire to pull them off the plug, pull the actual cap. You don't want to break the plug wire.
Oh...be careful putting the spark plug in the head, do not cross thread the plug!
Keep up the good maintenance and ride, ride, ride.
Chris GL1800
Previous rides:
125 Vespa; CB350 Honda; CB360 Honda; CB500 Honda; CB550; GL 500 Silverwing; HD softail; HD Streetglide;
And finally....a 2009 GL1800 Goldwing; NAV, Comfort, Premium sound; Dark metallic blue.
Proud Patriot Guard Rider
chrisgl1800 is offline
post #3 of 10 (permalink) Old 01-17-2011, 02:18 PM
L2R
L2R's Avatar
torque wrench and a service manual
Get a good digital torque wrench if you don't have one.
This should be a requirement before you work on your bike.
If you haven't used one, read the directions, it's a precision tool.
It matters how you store and if you bring it down from 85 lbs to 25 it may not work properly.
If you never used one and get the recommended torque setting for your oil plug, spark plug etc. you will scare yourself as to how little leverage it takes.
These aluminum blocks won't take overtorque or cross threading.
80 bucks is peanuts compared to pulling or replacing a motor.
50 bucks for the manual is also minimal as it will give you the confidence to do your own maintenance.
"The best way to get a bad law repealed is to enforce it strictly." Abe Lincoln
L2R is offline
post #4 of 10 (permalink) Old 01-18-2011, 11:12 AM
budoka's Avatar
Garage
Service mnual states 16,000 mi for plug replacement, but I know there's riders out there that go over double that and then some. I'll likely inspect mine come spring but that's about it. Good point by l2r about the digital torque wrench, it sure opened my eyes.
Daryl
budoka is offline
post #5 of 10 (permalink) Old 01-18-2011, 11:37 AM
Lifetime Premium
Ron Robertson's Avatar
I'm not trying to be a jerk, but don't get the plug wires mixed up, get them on the wrong plugs and your wing won't run worth a crap. I only say this because I've fixed a couple bikes after the owners changed the plugs and got a couple plug wires mixed up. Do it one at a time and you can avoid this happening.
From the Northwest Corner.
Ron
Ron Robertson is online now
post #6 of 10 (permalink) Old 01-18-2011, 09:28 PM
Ron
Do one at a time and you won't make that mistake....
Chris GL1800
Previous rides:
post #7 of 10 (permalink) Old 01-19-2011, 09:39 AM
Junior Member
re:Grandy
Hi Grandy,
Spark plug problem is rear problem and everyone face this type of problem. This problem is solved at home very easily whenever your bike plug has got a problem in starting in winter then remove plug and heat the spark plug after it plug in your bike. Your bike will be start shortly.
Take care!
Finklea.
Stainless Steel Hitch Covers
Finklea is offline
post #8 of 10 (permalink) Old 01-19-2011, 12:52 PM Thread Starter
Grandy's Avatar
All great information, thanks so much
** IDMWT # 34 **
Grandy is offline
post #9 of 10 (permalink) Old 01-19-2011, 01:02 PM
lonewolftx's Avatar
Here is an old mechanics trick to avoid cross threading. First of cut about 5in of rubber tube that will fit firmly on the top of the plug. Gap the plug with a good wire plug feeler guage. Hold the tube by the other end with your finger tips and insert the plug then tighten it finger tight with the tube. Pull off the tube, torque the plug down to specs and re attach the plug wire. Be sure it is seated well on the plug.
U.S. Navy 1966-1972
Disabled Vet
AMA
GWRRA
2012 Goldwing. Red and silver
lonewolftx is offline
post #10 of 10 (permalink) Old 01-20-2011, 07:25 PM
GoldDigger's Avatar
Yes, and add a little elect. grease to the boot and it will slip on easier and seat onto the plug better.
CMA #146086
'08 Navi 1800
'98 Aspencade,
'02 Shadow 1100
Patriot Guard Rider
GWRRA Chapter MS-L
Jeremiah. 29:11
God says, "I have plans to prosper you, not to harm you..."
GoldDigger is offline
Human Verification
Linear Mode Linear Mode
